Temperature gauge fluctuating
Recently the temp gauge in my 72 has been fluctuating from normal temp to a hotter reading. My first instinct was the thermostat so I replaced it yet still had the same problem. I checked the temp with a temp gun when the gauge showed both hot and normal reading and the engine is staying at a consistent upper 180s. I also tried a new sensor and have had no success so far. Any ideas what could be causing this? I know it's not my headers because it was fine for a long time until just recently and nothing looks out of the ordinary under the hood
Old member
Have you checked the water level lately?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Temperature gauge fluctuating
if your temp is normal the only thing left is the gauge itself. some peope say a 160 thermostat does not help but I put one in mine and temp never exceeds the 1/4 mark and heater still works.
If coolant was low the actual temp will fluctuate. But, you say the gun said the temp is consistent. I'm thinking you have a short or a ground issue. If you ground out the sensor wire it will spike all the way up. I would start with pulling the instrument panel, check printed circuit for general condition first. while in there check to see if panel is grounded well to body metal.
#5 | |
By fluctuating, do you mean it's slowly dropping and climbing, or is it spiking low or high and returning? A spike would almost certainly be a ground issue, but slowly fluctuating could be an intermittent high resistance from a poor connection, low coolant, faulty gauge, or incorrect temp sender. Where did you purchase the temp sender, and do you know the ohm rating on it? Parts stores RARELY ever carry the correct sender. |
#6 | |
