Old 12-16-2015, 07:56 AM   #1
30 a truck
30 a truck's Avatar
switch?????
Let me start by saying that I did not disassemble this truck. When I removed the old wiring harness from the firewall, the entire harness came out. Everything was loose except the fuse panel. This switch came out with the harness. I am installing a new AAW harness (nice). Where does this switch go??? It is not the neutral safety or brake light. I see no way or no how it could have been 'rigged" to be a park brake light. Help?
30 a truck is offline   Reply With Quote
Old 12-16-2015, 08:10 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: switch?????
I have never seen that before in one of these model trucks. It could be some kind of brake switch but it's not factory to these vehicles.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-16-2015, 08:47 AM   #3
midniteblues
midniteblues's Avatar
Re: switch?????
Looks to be a turbo 400 trans kick down switch. It mounts on the gas pedal bracket.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-16-2015, 09:45 AM   #4
30 a truck
30 a truck's Avatar
Re: switch?????
When I got the truck, it had a TH350 with it. Spid says M49. Is M49 TH400?
Old 12-16-2015, 09:59 AM   #5
midniteblues
Re: switch?????
Can't help ya there that's a question for the spid gurus.
But if there was wireing going to it I would say it was a 400 truck. Or if there was no wires perhaps someone installed the gas pedal bracket from another truck an just didn't remove the switch.
Pretty sure the earlier trucks had a switch mounted at the carb linkages.
Old 12-16-2015, 10:14 AM   #6
engineer_gregh
engineer_gregh's Avatar
Re: switch?????
I've read several threads that state M49 could have been either a Turbo 350 or 400. The picture looks like the kick down switch for the Turbo 400 to me.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 12-16-2015, 10:44 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: switch?????
Take a look at this older thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=319667
It also shows the optional Manual Throttle hooked up.
LockDoc
Leon
Old 12-16-2015, 12:23 PM   #8
snipescastle2
snipescastle2's Avatar
Talking Re: switch?????
Ditto on the 400 TH kick down switch....
Ben
snipescastle2 is offline   Reply With Quote
Old 12-16-2015, 02:05 PM   #9
davepl
davepl's Avatar
Re: switch?????
Lockdoc wins, part of a manual throttle knob setup.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-16-2015, 02:09 PM   #10
30 a truck
30 a truck's Avatar
Re: switch?????
Asking because I don't know. If it is manual, what does the power do? It has a place for 2 wires.
Old 12-16-2015, 02:17 PM   #11
davepl
davepl's Avatar
Re: switch?????
User pryorstemmed has one and had to hook the wires up, but didn't post how he did it, you might try him.
As a random guess, maybe it's another "step" in the neutral safety so you can't start it when the hand throttle is engaged?
Old 12-16-2015, 02:21 PM   #12
cleszkie
cleszkie's Avatar
Re: switch?????
The switch has nothing to do with the manual throttle. The switch is the TH400 kickdown, as several folks have already pointed out.
cleszkie is offline   Reply With Quote
Old 12-16-2015, 02:23 PM   #13
davepl
davepl's Avatar
Re: switch?????
Are you saying that even trucks without manual throttle use that same switch on the pedal assembly to sense kickdown?
My TH400 kickdown looks nothing like that in 1970. But that switch looks EXACTLY like the switch on the manual throttle bracket for 70 or later (the 67-68 was a cruder system with no switch). So maybe it's part of the kickdown only and just happens to be on the same bracket?
I'm not disputing you - it could well be that the picture of the manual throttle includes it in the photo but that the bracket part is ALWAYS present even without the manual throttle and we're just looking at it as a unit incorrectly. So perhaps that whole piece of it is always there and the manual throttle cable is just added to pull (while in 67-68 it went through the firewall).
Old 12-16-2015, 03:17 PM   #14
cleszkie
cleszkie's Avatar
Re: switch?????
The style/mounting location of the kickdown switch might be dictated by whether a manual throttle was included on the gas pedal bracket or not. I don't know.
All I know is that the manual throttle simply pulls the accelerator pedal to the desired location and holds it there. It has no mechanical or electrical connection to the kickdown switch. I can think of no reason why it would. I have a manual throttle on my 72 Blazer. I use it to set and hold my rpms up while in neutral to generate more current for my electric winch. Folks with PTOs use it to increase rpms in neutral to increase hydraulic pressure.
Old 12-16-2015, 03:29 PM   #15
LockDoc
LockDoc's Avatar
Re: switch?????
The switch and manual throttle are two completely different things. Neither has anything to do with the other, they just happen to be mounted on the same bracket in '71-'72. The one wire from the kickdown switch goes to the TH400 Transmission to electronically shift it into passing gear when the pedal is floored.....
LockDoc
Leon
Old 12-16-2015, 03:34 PM   #16
davepl
davepl's Avatar
Re: switch?????
Originally Posted by LockDoc View Post
The switch and manual throttle are two completely different things. Neither has anything to do with the other, they just happen to be on the same bracket in '71-'72. The wires from the kickdown switch go to the TH400 Transmission....
LockDoc
Thanks! Makes more sense. On my '70 the kickdown is under the hood, so it didn't make sense on first impression.
Old 12-16-2015, 03:37 PM   #17
LockDoc
LockDoc's Avatar
Re: switch?????
I edited & added to my last post....
LockDoc
Leon
Old 12-16-2015, 07:32 PM   #18
Andy4639
Old member
Andy4639's Avatar
I have looked at hundreds of these trucks and have never seen this part! So I learned something new to! All the kick downs I have ever seen where out in the motor compartment!
Old 12-17-2015, 06:39 AM   #19
30 a truck
30 a truck's Avatar
Re: switch?????
I learn something just about every day when I visit this site.
I also learned that not all parts go with the truck you find them in. I am still puzzled as to why this 400 kickdown was in this truck. Oh well, life goes on.
Thanks for the help guys.
Old 12-17-2015, 07:18 AM   #20
Boog
laying low
Boog's Avatar
Re: switch?????
As old as these trucks are we'd be foolish to assume any part of them is original from manufacturer unless we are looking at a fully documented original owner vehicle and even then there is still a smidge of doubt to be had.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-17-2015, 07:56 AM   #21
midniteblues
Re: switch?????
Little off since your truck is a oe 350ci.not very common to back up a 350 with a th400.
Was there a branch in your harness that plugged into it????
Guys I don't think we will ever stop learning something new when it comes to these trucks
Old 12-17-2015, 08:55 AM   #22
30 a truck
30 a truck's Avatar
Re: switch?????
When I pulled the old harness out, nothing was hooked up, just screwed to the firewall. This switch had 2 brown wires connected to it. The other end was just hanging, already unhooked.
No big deal as I am adding a new AAW harness. I don't need this switch now that I know what it is.
Thanks for all the help. This thing is a breeze to wire compared to the last one I wired.
Old 12-17-2015, 09:09 AM   #23
midniteblues
Re: switch?????
That's a sweet ride
