Old 12-16-2015, 01:33 PM   #1
Henner
Temp Sender Problems
Ok guys I have read and read and can not find or get a definate answer on this. I am sure by now someone has figured this out. Installed a 350 in place of a straight 6, the OE temp sender is a 1/2" and it appears i need a 3/4" temp sender for the intake or head. I can not for the life of me find a 3/4" that will let me use my factory gauge.
Thanks,
Henner is offline   Reply With Quote
Old 12-16-2015, 01:49 PM   #2
smoked68
smoked68's Avatar
Re: Temp Sender Problems
You may have to go get some adaptors from like Home Depo to make it work. Or... Get a mechanical gage, auto meters are nice
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 12-16-2015, 02:01 PM   #3
davepl
davepl's Avatar
Brass bushing. Way easier than the other way, I paid like $50 for a tap so I could cut the threads in an iron intake to take the big fitting!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-16-2015, 02:53 PM   #4
Henner
If I do a 3/4" to 1/2" bushing will the temp sender sit deep enough into the head?
Old 12-16-2015, 03:22 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Thanks,
Have you actually tried the sender in the head? The head should be 1/2". I have seen intakes 3/4" but not heads....... Sounds like you have a full gauge panel but just as a heads up the senders for the idiot light gauge panels are different than the full gauge panels.
LockDoc
Leon
Old 12-16-2015, 03:42 PM   #6
Henner
The heads are aluminium aftermarket heads and are definately 3/8" threads. And yes I have full gauges.
Sorry for the confusion on the above posts saying 3/4".
Old 12-16-2015, 05:20 PM   #7
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
I had the same issue with the Vortec heads. I bought a new brass sender for the truck and carried it to the local machine shop and had them turn it down in the lathe and then rehread it to fit the heads. There is no other sender that will give the correct resistance for the factory gauge.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 12-16-2015, 05:37 PM   #8
kingstrider
kingstrider's Avatar
I used a 1/2 npt to 3/8 npt bushing when I did mine.
1972 Cheyenne Super swb:
http://67-72chevytrucks.com/vboard/s...d.php?t=684318
kingstrider is offline   Reply With Quote
Old 12-21-2015, 09:51 AM   #9
dutchmanz
dutchmanz's Avatar
How well does the temp gauge work with the adapter in place? I didn't go this route since the sender was not in the flow of water.
Old 12-21-2015, 10:51 AM   #10
LockDoc
LockDoc's Avatar
Ah, that makes more sense.
I think the gauge would at least be off some if you used a reducer bushing. I'm not sure about that because I have never tried it. I tried the intake and mine didn't read even close in the intake because of the thermostat opening and closing. I have had a couple turned down for the GM crate engines I used. Make sure you have the sender for gauges and be sure they don't turn it down or thread it too far back or it will break off when you try and tighten it down. I drilled and tapped the head on my LS1 and that worked out good.
There was a member on here turning them down but I don't know if he is still around or not....
LockDoc
Leon
Old 12-21-2015, 12:11 PM   #11
cooperhw
cooperhw's Avatar
I used the adapter and mine works fine. I think it's all bathed in water whether it's "in the flow or not" so hot water will find every surface it's exposed to.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 12-21-2015, 01:02 PM   #12
FirstOwner69
FirstOwner69's Avatar
LockDoc
Here's a thread with good discussion and contact info for member brian mac (see post 23) who modifies senders. His last visit to the forum was Dec. 15.
http://67-72chevytrucks.com/vboard/s...d.php?t=627880
FirstOwner69 is offline   Reply With Quote
Old 12-21-2015, 03:00 PM   #13
70LonghornCST
Moderator
70LonghornCST's Avatar
I had this same problem. My crate engine sensor opening would not accommodate the correct 67-72 sensor. I asked the same question HERE.
I was going to get an adapter, but a member chimed in who was able to machine a new OEM style to the correct size. There was also discussion about possible incorrect readings if using a brass adapter, stating that the sending unit needed to be positioned in a specific location relative to the heads, as well as the brass acting as a heatsink. Since brass is an alloy compound, its conductivity varies significantly to iron.
However, I am not too convinced about the conductivity issue, as temperature sending units are made of brass. Moreover, I was told at one point that adapters were often used on high performance applications without any issues.
My thinking is this: adapters are inexpensive. Give it a try. If the reading looks odd, or incorrect, look into getting the sensor machined to the correct size to fit your heads.
Richard
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 12-21-2015, 03:13 PM   #14
Henner
Thanks guys, I took two steps backwards this weekend while hooking up a volt meter from a 86 chevy. Appears I burn't up my circuit board. I posted over in electrical trying to get some ideas on what went wrong.
Old 12-21-2015, 03:19 PM   #15
davepl
davepl's Avatar
I have a spare PCB if you get desperate (I'm in WA so not nearby). They're easy enough to find but if you get stuck and can't find one, let me know!
