12-16-2015, 04:38 PM | #1 |
High hump vs low hump
Been getting my cab stripped down and the hump just caught my eye. 62 low hump. I'm going to be running a factory bell housing with a Saginaw car 4 speed. Just a guess rite now, but do I need a high hump or will it sit far enough forward or back that the low hump works?
12-16-2015, 05:34 PM | #2 |
Enjoy your truck
Re: High hump vs low hump
Low hump worked with my Muncie M21. Not a lot of clearance but no interference.
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
12-16-2015, 06:46 PM | #3 |
Thank you sir. The shifter is what had me worried. I think they mount in the same location on Muncie and sag. Was worried the shifter would come up in the transition from low to floor.
12-16-2015, 07:31 PM | #4 | |
Enjoy your truck
Greg.
12-16-2015, 07:44 PM | #5 |
Thanks. At least it will work and now I know what to expect.
12-17-2015, 01:50 AM | #6 |
60-66 Nut
In my opinion a low hump floor would be preferable with a car 4 speed trans and a standard car shifter. With a high hump you can get different shifter rods and the riser bracket that raises the shifter up. Otherwise with a high hump and a standard car shifter, the hole in the floor needs to be fairly large to acomodate the swing of the shifter.
02-23-2016, 03:27 PM | #7 |
Greg, would you be able to get me any measurements on hole location. My cab is off the frame and I will be putting motor and trans in frame before cab goes on . My shifter is bolted to the trans without the lever on it. I hate to take it apart and don't want it in the way of sitting the cab down. Any measurements appreciated.
02-23-2016, 08:13 PM | #8 | |
Enjoy your truck
Greg.
02-23-2016, 10:30 PM | #9 |
Thank you sir. I can work with that.
02-23-2016, 10:35 PM | #10 |
Enjoy your truck
My pleasure.
Greg.
