Old 12-16-2015, 05:11 PM   #1
bjkttr
bjkttr's Avatar
Best motor mounts ? Ls swap
I have a 65 c10 I am looking to swap a chevy 6.0l into. What is a good motor mount to use?
bjkttr is offline   Reply With Quote
Old 12-16-2015, 05:14 PM   #2
Mathew21
Mathew21's Avatar
Re: Best motor mounts ? Ls swap
I used my stock V8 perches with dirty dingo LS sliders fr my 5.3 swap in my 66'.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 12-16-2015, 05:17 PM   #3
bjkttr
bjkttr's Avatar
Maybe a stupid question but how do I know what motor mouth I have in the truck now? There was no motor in the truck when I bought it.
Old 12-16-2015, 07:24 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Take some pics of what you have and show us.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-16-2015, 09:58 PM   #5
TopFuel1966
TopFuel1966's Avatar
http://www.earlyclassic.com/catalog....ry=New%20Items
TopFuel1966 is offline   Reply With Quote
Old 12-17-2015, 11:13 PM   #6
zach_carver
zach_carver's Avatar
I'm also doing a 65 as of right now, I'm using factory perches with dirty dingo sliders. Everything has lined up perfectly so far, mount wise anyways lol
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 12-25-2015, 05:08 PM   #7
bjkttr
bjkttr's Avatar
Sorry for the delay been really busy. I seen the dirty dingo ones I was thinking about using them. Just want to know what my best options are before I order. Here is a picture
Old 12-25-2015, 08:04 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
IMO, for so many of these swaps, there isn't a "best". Most of the time, its your choice/budget that determines it, unless your running a combo that has extra requirements (4x4, odd motor, custom kframe etc).
All of the "plate" adapters work the same, so if you go that route, just find one that fits your budget (and isn't chinese steel from ebay). The transdapt ones are afforedable, and there are even a few guys making and selling their own.
The Dingo mounts are nice if you need the adjustability, but they cost a bit more.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-25-2015, 09:42 PM   #9
foamypirate
foamypirate's Avatar
Tejas Steelworks has a nice setup that will allow the stock truck A/C compressor to clear the frame, if that's important to you. They also have a swap guide on Facebook to go along with their mounts. Just look up Tejas Steelworks on FB.
foamypirate is offline   Reply With Quote
Old 12-25-2015, 09:49 PM   #10
bjkttr
bjkttr's Avatar
It looks like Tejas Steelworks focus more on the square body c10.
Old 12-26-2015, 12:25 PM   #11
clemsonteg
I'm considering the dirty dingo non-slider mount plates. They are still adjustable. I like that dirty dingo explains the engine placement from the SBC. Engine mounts like these http://www.jegs.com/i/Trans-Dapt/969/4575/10002/-1 say 1" set back, but setback from where? Based on Glock's thread in the faq, these would be more like the factory SBC mount position.
clemsonteg is offline   Reply With Quote
Old 12-26-2015, 01:23 PM   #12
foamypirate
D'oh. I missed the part about the 65' in the original post.
Old 12-27-2015, 12:29 AM   #13
MalibuSSwagon
usually a 1" setback plate places the bellhousing flange on the block in the same position as a SBC. So if you are reusing transmission then your crossmembers, driveshaft etc doesn't have to move. Especially good for 4x4 trucks. In my case I reused the SM465 that was in the truck and basically made it a drop in swap. Also most swap headers like Patriot, Doug thorley; are designed around using 1" setback plates. The Car Shop CSP2370 are my go to when doing a swap.
However, one thing to consider. If firewall clearance to the back of the heads on your SBC is tight, 1" setback may not work for you. While SBC's have a flange of about 1" on the rear, the LS is flush to the heads. Just look at yours and you'll see.
MalibuSSwagon is offline   Reply With Quote
