Old 12-16-2015, 06:49 PM   #1
Eagle9502
Trying to find the correct big block parts
I'm trying to piece together a '68 big block. Can anyone help me with pics or possibly even part numbers for the following parts:
-Exhaust manifolds
-Cooling fan blade
-Air cleaner
-Quadrajet carburetor
Thanks!
Eagle9502 is offline   Reply With Quote
Old 12-18-2015, 03:05 PM   #2
Eagle9502
Re: Trying to find the correct big block parts
Bump
Old 12-18-2015, 03:27 PM   #3
davepl
davepl's Avatar
You should probably post in the parts forums, better chance of catching one of the people with the parts.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-18-2015, 03:57 PM   #4
Eagle9502
I tried to create a post in there but it said I don't have permission. Is there something I need to do first?
Old 12-18-2015, 04:03 PM   #5
Eagle9502
Nevermind, I see that I have to be a Premium Member to create a thread in the Classified sections.
Old 12-18-2015, 04:14 PM   #6
leftybass209
leftybass209's Avatar
Go here, http://67-72chevytrucks.com/vboard/s....php?p=5781194 and download the 1968 manuals. Then, look for part numbers corresponding to what you want.
The carb is a Rochester 4MV part number 7028211, which is specific to the 396. That'll get you started.
leftybass209 is offline   Reply With Quote
Old 12-21-2015, 04:57 PM   #7
Eagle9502
Thanks! I have the assembly manual but didn't have those.
Old 03-03-2016, 04:57 PM   #8
Eagle9502
I saw where the service manual says the correct part number is 7028211, however I have found two sources that say the correct number is 7028217.
I have located a 7028217 EG, the guy says it's the original carburetor off of his '68 Chevelle 396/325 hp with a 4 speed.
The books I have seen that show the 7028217 to be correct for the '68 396 truck lists this number and does not specify standard/automatic transmission.
Can anyone shed some light on this? I'm wanting to pull the trigger on buying the 7028217 if it is correct.
