Old 12-16-2015, 10:43 PM   #1
qwik
qwik's Avatar
Old air under dash vents
I'm about to pull the trigger on an old air ac system. I want to use the under dash vents, I'm concerned about the driver side vent interfering with 67-68 emergency brake handle. Anybody done this?
qwik is offline   Reply With Quote
Old 12-17-2015, 09:50 AM   #2
wpotter
wpotter's Avatar
Re: Old air under dash vents
You will need about 3 inches from the kick panel and 3 inches down from the dash to clear a round under dash vent. The rectangle under dash vents hang down about 2 inches and are 6 inches long. On the Vintage Air kits you get round vents that go in the dash so there is'nt any clearance issues. Hope this helps.
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
Old 12-17-2015, 01:07 PM   #3
qwik
qwik's Avatar
Thanks, I'm trying to avoid cutting the dash.
Old 12-17-2015, 03:01 PM   #4
bigmac73
bigmac73's Avatar
so I was just looking at the OLD air under the dash units, I am guessing that you are removing all the factory heater parts??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-17-2015, 06:06 PM   #5
wpotter
wpotter's Avatar
I am curious to know myself. All the installs I've done have been 69-72 with the foot pedal. Can you provide a picture with measurements from dash down to handle and from handle over to kick panel. I don't blame you for not wanting to cut the dash, especially if it's a done truck.
Old 12-17-2015, 06:43 PM   #6
qwik
qwik's Avatar
http://www.oldairproducts.com/catalo...te-p-5102.html
This is the kit I'm probably going to use.
Old 12-17-2015, 06:50 PM   #7
qwik
qwik's Avatar
The handle is 2" (tapers up towards the column) down as it passes the plane of the dash.
Old 12-17-2015, 07:38 PM   #8
Smokinhart
Smokinhart's Avatar
I'm not done with interior and console yet but we did the under dash vents and matched up the spacing side to side. We simply turned the parking release lever 1/4 turn. It's actually easier to grab on to.
[IMG][/IMG]
1969 swb.
5.7 TBI. 700r4
255/50r17 on AR PVD coated rims
Smokinhart is offline   Reply With Quote
Old 12-17-2015, 11:30 PM   #9
Dustytrix
Looks good Smokin glad you posted.
Dustytrix is offline   Reply With Quote
Old 12-18-2015, 08:35 AM   #10
bigmac73
bigmac73's Avatar
[IMG][/IMG]
I have to ask about those seats , what is the manufacture and model of those seats?
Mike
