Old 12-17-2015, 12:14 AM   #1
Blanco_53
Engine knocking
Looking at a 80 k10 swb and sounds like the engine is knocking a
Little , should I be worried about it or just buy it for cheap and fix it ? How long can it be driven without fixing it?
Blanco_53 is offline   Reply With Quote
Old 12-17-2015, 04:07 AM   #2
68c10owner
68c10owner's Avatar
Re: Engine knocking
There is no way to tell how long it will last.
Anthony
68c10owner is offline   Reply With Quote
Old 12-17-2015, 04:15 AM   #3
74CustomK20
74CustomK20's Avatar
Re: Engine knocking
I had a s10 4.3 with a knock. Lasted 4 years before I sold it. Bought a 77 c30 350 with a knock. Literally made it 2 blocks.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-17-2015, 04:35 AM   #4
andrewmp6
Re: Engine knocking
Depends a lot on where its knocking from and if its a spark knock or not.
andrewmp6 is offline   Reply With Quote
Old 12-17-2015, 10:32 AM   #5
cadillac_al
Re: Engine knocking
I wouldn't trust it very far. If it is priced accordingly, just plan on putting some bearings in it or a crank kit. Of course that snowballs into an oil pump, timing chain, possibly cam and lifters and a few other odds and ends. Then you will have a truck you can depend on.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-17-2015, 12:20 PM   #6
Dead Parrot
Re: Engine knocking
Can you afford the price of the truck + about $2000 for a new crate motor plus the various things you discover need replacing during a motor swap? Are you are willing to put in the labor to make it happen?
If yes, and the rest of the truck is what you want and priced accordingly, consider buying it. If no, pass.
If you are prepared for a worse case scenario then anything less then that seems like a bargain.
A dying PS pump can make a noise that sounds a lot like an engine knock as can a subtle exhaust leak.
Dead Parrot is offline   Reply With Quote
Old 12-31-2015, 12:11 AM   #7
barry1982
Re: Engine knocking
Does it knock all the time, or just when driving? I had a weird experience years ago. Had a 78 Camaro Z-28. It had the 350/350 auto. One day is started "knocking" while accelerating. Let off the gas, it would quit knocking....??
I licenced mechanic told me it was a rod bearing for sure.....I was puzzled because a rod bearing should knock all the time. I took it home, and pulled the inspection cover off of the transmission, exposing the bottom of the torque converter/flex plate. Turns out my flex plate was cracked between the large "punch out" holes in two places. When the car would accelerate, the torque converter was pulling back too far, and ticking on the bell housing. This sounded EXACTLY like a rod knock. I pulled the tranny, installed a new $30 flex plate, and drove the car for eight years with the same engine.
barry1982 is offline   Reply With Quote
Old 12-31-2015, 12:36 AM   #8
cheepin
Re: Engine knocking
I actually had about the same issue. Bought a 79 Suburban with a rebuillt 400. Started knocking 2 weeks after. I thought it was a bearing forsure. I crawled under it looking for lose anything. I could see daylight between the motor and trans. Turns out 3 bellhousing bolts fell out and the other 3 were lose. This cracked the flexplate around the crank.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
