Old 12-17-2015, 07:56 AM   #1
ckeenum
62 Chevrolet C10 StepSide
Hello all,
I am new to the GM life and need a little assistance. I recently traded my 1990 Dodge D150 for a 1962 Chevrolet C10 StepSide 2wd. It has no motor or trans, body is is decent shape and I plan to build it to drive. Firstly, I cannot find any decent images of the front steering setup of this model as mine is missing some other parts and the steering is currently just free (no real direction for either wheel). I think I need a drag link but do not know enough to understand exactly what I need. Tie Rod ends are just hanging with no connection. Secondly, I know I can swap components from a 80's model C10 to convert my front rotors to 5 lug and disc brakes, but what about the back. Like I said, I am looking to make this thing a driver and yes I know there is no problem with drums, it is just a preference. Any other comments or ideas, feel free to post.
ckeenum is offline   Reply With Quote
Old 12-17-2015, 01:38 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: 62 Chevrolet C10 StepSide
I'll try to get you a pic later of my stock front end. They do see a disk brake conversion for the 60-62 trucks that you can change to 5 lugs and a 2.5 drop if you want. That's what I'm planning to do to mine in the future because I don't want to do all the mods to get it in. Some have done the 80s conversion and came out good. Marke01 did one to his truck, just look it up in the search. What are you planning on for the engine and trans?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-17-2015, 02:00 PM   #3
62stepside longbox
62stepside longbox's Avatar
I'll get some pics of my stock 62 front end when I get home.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 12-17-2015, 02:18 PM   #4
ckeenum
I haven't made anything official. I figure a 350 will be the easiest to find and cheapest (considering budget). I am open to slapping anything in it however. I haven't done any research into transmissions and do not know where to start. I don't know whether stock or aftermarket, my truck has a clutch and stick on the floor. I want to get it lower, not planning on bagging it yet. Lowering coil springs or something, haven't done enough research yet.
Old 12-17-2015, 11:00 PM   #5
Monte's62
This is all I have but it may help a little. My perches are for a sbc so that may help you if you go the 350 route, which I would recommend. Also if you do want to lower cheaply, I would say drop spindles which I think are available for 60-62 trucks now and crank your torsion bars down to a safe or desired level.
Monte's62 is offline   Reply With Quote
Old 12-17-2015, 11:06 PM   #6
Monte's62
Oops, meant to send this one.
Old 12-18-2015, 01:05 AM   #7
Captainfab
60-66 Nut
Welcome to the forum
Since there is no engine in your truck, this would be the time to switch the whole front suspension for a '73-'87 suspension. It can easily be done in a weekend.
Old 12-18-2015, 09:32 AM   #8
ckeenum
Originally Posted by Monte's62 View Post
Attachment 1478149
Thanks for the info, I am sure this will help me along the way.
Old 12-18-2015, 09:35 AM   #9
ckeenum
So I have read a couple of different post in regards to this. There is the "take the cross member and all" or there is the "take everything from the control arms, springs and spindles". Which is the better option. Also, any infor on swapping to disc out back?
Old 12-18-2015, 10:21 AM   #10
Monte's62
Do you have the stock torsion bar suspension? If so, as Capt mentioned now would be the time to convert. You can pick them relatively cheap and there are several good threads that explain this conversion in detail. The next question is how low do you want to go and are you ever planning on bags? It sounds like you just want to lower on the cheap. One of the reasons to get away from stock 62 suspension is better availability and cheaper bushings, more adjustability with springs, until recently drop spindles, discs and 5 lugs. I mentioned drop spindles and cranking the torsion bars as one cheap option, but if you want it lowered and plan on keeping it most guys will recommend converting.
Old 12-18-2015, 04:38 PM   #11
ckeenum
I will get pics and post later. I am pretty sure it is mostly original. I only plan to lower it a little. I am not looking to touch the floor but when or if I decide to throw a set of wheels on it(20's or offset 18's and 20's or 20's and 22's), I want it to looking proportionally correct.
Old 12-19-2015, 01:13 AM   #12
Captainfab
60-66 Nut
On the '60-'62's you must change the crossmember if you want to upgrade to the better front suspension with disc brakes. As mentioned above, you can buy aftermarket dropped spindles for the '60-'62 front suspension. It's just a matter of what you want and what your budget is.
As for rear disc brakes, I make 5 different rear disc brackets. Three for the 5 x 5" wheel stud pattern and 2 for the 6 x 5.5". However these are only for the '64-'82 12 bolt and '79-'87 10 bolts, To my knowledge there are no rear disc brackets or conversion axles for the Eaton HO32/33 differential that originally came under the '60-'62 Chevy trucks.
Old 12-19-2015, 02:06 PM   #13
number10
We did the cross member conversion on a 66 using one from a 1986 at home and love it. Had to fab some upper shock mounts and drill a couple of holes but for what you get in the trade off is great. I did a 350 with T5 and truck is a ball to drive. All the info came from this site and was spot on. The trans swap was done in the driveway over a few days as the driveshaft was sent out for shortening and balance with new u joints. May seem cheaper to use the original crossmember and convert it but wont in the long run
number10 is offline   Reply With Quote
