Old 12-17-2015, 01:58 PM   #1
chevytoban
Belltech 5353 springs
I recently purchased a set of rear drop springs for my 69 -910 and I'm having issues with fitting the bottom spring retainer. I'm using the 1"spacer on the bottom as I purchased the kit for a 3"drop rather than a 4" My problem is that when I go to install the factory retainer (Ive ordered a new set)the lower spacer which comes up the middle of the spring and interferes with the retainer placement. Anyone else have this problem. Thanks in advance
chevytoban is offline   Reply With Quote
Old 12-17-2015, 02:54 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Belltech 5353 springs
I would think that the cup would sit on top of the spacer to sandwich the spring against it but youre going to need 5.5 inch bolts for that.
1967custom
michael bustamante is offline   Reply With Quote
Old 12-17-2015, 06:54 PM   #3
chevytoban
I asssumed that would also be the case, I have attached a picture of what it looks like sitting on top of the 1"spacer
Old 12-17-2015, 06:58 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I dont think I would run a spacer there.
I would want it bolted solid to the trailing arm.
Keith
Convert to disc brakes.
