Old 12-17-2015, 06:40 PM   #1
cfan10
cfan10's Avatar
Cool Video troubleshooting? No start?
1984 c10 305 4 barrel edelbrock 1406, th350
No start has gas in driver tank, only using one tank. Plugs are .45 gap the timing on damper is 4 btdc, new fuel pump, lines and clear filter fuel is getting up to the carb. New arc seal in distributor cap. Firing order is right, but the two of the plugs don’t look great most are sooty and two are rusty, they aren’t even a year old. As always your help is greatly appreciated.
youtube video
https://youtu.be/QKFsnwbMZF8
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 12-17-2015, 06:41 PM   #2
cfan10
cfan10's Avatar
Re: Video troubleshooting? No start?
First photo is the #1 spark plug.
Old 12-17-2015, 06:53 PM   #3
geezer#99
geezer#99's Avatar
Loosen the distributor and rotate it 1/2 inch (or there abouts) counter clock wise.
Leave it loose so you can advance or retard it until it starts.
Old 12-17-2015, 07:01 PM   #4
cfan10
cfan10's Avatar
Thanks. My mom actually has insisted that it was a timing issue.
Old 12-17-2015, 07:28 PM   #5
geezer#99
geezer#99's Avatar
Do you have a fuel regulator set at 5 psi for that carb?
Eddy carbs don't like fuel pressure.
Old 12-17-2015, 08:35 PM   #6
68c10owner
68c10owner's Avatar
Before moving the distributor you need to verify that you are getting spark. Pull a plug wire, stick a screwdriver in there and going it out while someone turns the key. If you have spark and you have fuel then you can check firing order. BTW, a 1/2" is ALOT to move the distributor. The littlest movement will change timing several degrees.
Anthony
68c10owner is offline   Reply With Quote
Old 12-17-2015, 09:59 PM   #7
geezer#99
geezer#99's Avatar
1/2 inch is 6 to 12 degrees depending where you measure.
Old 12-17-2015, 10:02 PM   #8
68c10owner
68c10owner's Avatar
Still not the orrect way to do it. And since the OP sounds like he doesn't have much experience that could really throw him off.
Anthony
Old 12-17-2015, 10:04 PM   #9
68c10owner
68c10owner's Avatar
Need to make sure there is spark before you even consider messing with the timing. Make sure the 12 wire is still connected to the distributor.
Anthony
Old 12-17-2015, 10:10 PM   #10
69heavychevy
69heavychevy's Avatar
Checked the carb and make sure it isn't all gummed up inside. The ethanol in fuel these days can cause alot of issues, especially with carbs.
I had a similar issue. It started as intermittent hard starting issues. After a few weeks it just wouldn't start. Opened up the carb and found all kinds of crud caused by the ethanol.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 12-18-2015, 10:58 AM   #11
Shugalou
Shugalou's Avatar
I recently had a no start issue myself. The truck is new to me so I am learning as I go.
I had an inline filter but checked the carb filter and the PO left the spring and cap in there - Have you checked that filter area?
Have you tried putting a bit of gas into the carb vent? Someone gave me that tip on this forum and after I did it with no success I suspected spark issue.
I pulled a plug and they were all black - I changed all the plugs and put a new inline fuel filter and it fired right up first try.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 12-19-2015, 03:36 PM   #12
cfan10
cfan10's Avatar
Cool Re: Video troubleshooting? No start?
She, lol but thanks.
Old 12-19-2015, 03:50 PM   #13
68c10owner
68c10owner's Avatar
Sorry, no name was posted.
Anthony
