Old 12-18-2015, 01:49 AM   #1
gono
gono's Avatar
LS interior wiring
I posted this in the LSX swaps also, but I'm hoping to get some input and pictures on routing my wire harness into my cab. I'm planning to mount the PCM under the seat. It's an LQ4 going into 56 Chevy 1/2 ton. Was thinking of going through the Trans cover, but wasn't sure if a lump would show under the carpet where the wires would run. Cheers
55' 3100 big window
55' 3100 big window
gono is offline   Reply With Quote
Old 12-18-2015, 05:32 PM   #2
Advanced Design
Advanced Design's Avatar
Re: LS interior wiring
I am considering doing the same with my Burb and planned to run the wiring through the floor under the seat then forward along the transmission.
If you are running a floor console you could use that to hide the wire bundle running forward.
Good luck with your build!
Advanced Design is offline   Reply With Quote
Old 12-18-2015, 05:35 PM   #3
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Not mine, just a pic I saved from somewhere, hope it helps.
ChuckDriver is offline   Reply With Quote
Old 12-18-2015, 05:37 PM   #4
gono
gono's Avatar
Have you figured out how you're going to run the wires through the floor? Bulkhead fitting or rubber boot? Just wondering how I'm going to seal the hole into the cab.
55' 3100 big window
Old 12-18-2015, 05:41 PM   #5
gono
gono's Avatar
That's what i needed, thanks. Just trying to get some ideas. Looking at the picture, I'm wondering about the seal between trans cover and cab floor. I'd like to avoid slapping down a bunch of silicone.
55' 3100 big window
Old 12-18-2015, 05:47 PM   #6
Advanced Design
My plan is a rubber boot. I like the picture Chuckdriver put up.
Old 12-18-2015, 10:46 PM   #7
joedoh
joedoh's Avatar
that blue truck has a nice layout but I am going to guess those 6x9s sound like tinny garbage.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-19-2015, 05:38 PM   #8
yossarian19
If you have moved the tank out from behind the driver's seat, I'd open up one of the fuel line pass-through holes and use that. Come into the under-seat area from behind, route wiring to one side or the other a bit & come up the body and to the back of the motor.
Hmm. Under the seat. I hadn't thought of that. I wound up going behind the dash on the passenger's side and it's really visible, which I'm "meh" about. If I ever do a second build on this... under the seat is the way to go.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 12-19-2015, 07:01 PM   #9
47 Fasttoys
47 Fasttoys's Avatar
How about behind the seat? I use the standard grommets found in most wiring kits and that seals it off well. Not a lot of water climbing up to the underside of the floor pan.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-19-2015, 07:23 PM   #10
jweb
jweb's Avatar
On my '51 I ran the main harness down the transmission and through a large marine grommet just behind the stock seat pan. The fuse block, relays, and obd port are under the dash for easy access, since I have a stock seat. Don't have any pictures right now, my truck is stored until summer.
jweb is offline   Reply With Quote
Old 12-23-2015, 11:57 PM   #11
Iceburgh
Iceburgh's Avatar
I tucked everything under the dash on my 53. Had the pump mounted to the bolts for the brake booster.
I will have to look for pics.
Came through the side of the cab behind the fender
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
