Old 09-18-2003, 09:21 AM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
Question HEI Plug wire recommendations
I know this question will garner some snide remarks, chuckles, and gafaws from a select few, so please have some fun with it.
For those that want to actually help, here is my question.
I'm looking for plug wires of the correct length for the following application.
It's a small block 350 with an HEI. It has stock rams horn manifolds, complete with the stock plug heat shields. I also have installed the stock looms that bolt on the back of the block. Other than the HEI, it's the OE stock setup. I want to route the wires as they were routed for the stock points setup. That is, behind the block and up under the rams horn manifolds.
The wires NAPA gave me for a small block HEI are too short to route properly. It sits at stock height so too long is better than too short. I don't plan on "laying" plug wires.
Has anybody solved this, and what wires did you use? I prefer not to make my own wires.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-18-2003, 09:34 AM   #2
tom hand
CCRider
tom hand's Avatar
1975 Corvette fits like a glove...they still had the ramshorns and were routed under like the trucks but had the HEI
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-18-2003, 09:37 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Thanks Tom!
Old 09-18-2003, 10:12 AM   #4
ddsmith
Glowing since 1978
ddsmith's Avatar
I second the 75 Vette wires. I put a set on my 69 C20 with a 350 and HEI. Worked great for me and I'm using the back of the block mounted wire looms also.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 09-18-2003, 11:17 AM   #5
tom hand
CCRider
tom hand's Avatar
Oh and I am pretty sure the engineers at GM did not design it with an HEI, so I think disqualifies you from using it...what if the next owner goes to NAPA and asks for plug wires for a 72 Chevy truck, they would get the wrong ones, bla bla bla...sorry somebody had to do it
Olive Branch MS
Old 09-18-2003, 11:26 AM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Tom, you're correct. I'm just proving my own point. I was hoping someone would be on the ball here.
Now kids, what have we learned here?:p
Old 09-18-2003, 01:21 PM   #7
Linus0014
Guest
Posts: n/a
CPNE: Do you have a pic of the stock wire looms for the front and rear. I'm doing mine that never had them before so any help would be nice, thanks...
Old 09-18-2003, 01:29 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
I can take a pic. PM me so I have a reminder to do so. It won't be until this weekend however.
Old 09-18-2003, 01:32 PM   #9
gman
What have I learned?
That there is actually someone else on here that likes.......should I say loves.........the look of "original".
I sure do, and everything on mine still is.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 09-18-2003, 01:43 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Amen! Let's start a club. We can have posters printed up like this for our ralley!
Old 09-18-2003, 01:44 PM   #11
CPNE
Resident Curmudgeon
CPNE's Avatar
For those that don't know, this is "Boz-All", poster child for my "Just Say No to Sawz-alls" campaign.
Old 09-18-2003, 01:51 PM   #12
gman
Where do I sign up?
Old 09-18-2003, 01:53 PM   #13
palallin
I'm in.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-18-2003, 02:00 PM   #14
ddsmith
Glowing since 1978
ddsmith's Avatar
But HEI isn't original. I also like the stock look but like the benefit of some newer things. HEI is one of them. My radio is another. My A/C system is aftermarket. If I had it to do all over again, I probably would have bought all the things missing on the truck when I bought it to return it to the stock A/C system setup. All in all my 69 C20 looks pretty much stock and will probably stay that way. As a friend of mine said " I like a truck that sits up proud" and the C20 certainly does that.
Old 09-18-2003, 02:05 PM   #15
CPNE
Resident Curmudgeon
CPNE's Avatar
Me too. I guess I'm "Stock-lite" "Looks great, less trouble"
Old 09-18-2003, 02:44 PM   #16
bucket
bucket's Avatar
i third the vette wires, altough I found that a few were either a tad long or a tad short. still the best fitting pre-cut I have found.
bucket is offline   Reply With Quote
Old 09-18-2003, 03:14 PM   #17
gman
Hey CPNE,
Did you buy a HEI dizzy that is designed to look stock? If so, what and where did you get it?
Old 09-18-2003, 03:17 PM   #18
CPNE
Resident Curmudgeon
CPNE's Avatar
No. I've been exposed for the fake that I am.
Seriously, to answer your question, it's a stock GM HEI unit. I'm sure you've heard of Pertronix. They make a setup that uses the points dizzy.
Old 09-18-2003, 03:45 PM   #19
gman
Yeah, i was just wondering if you bought some other high-end aftermarket unit designed to look stock. I've been looking at the Pertronix but just haven't gone there yet.
Old 09-18-2003, 06:11 PM   #20
junkyardjohn
junkyardjohn's Avatar
YOU ORIGINALITY GUYS CRACK ME UP. IF YOU'VE GOT A HEI INSTALLED... YOU'VE ALREADY BLOWN THE "STOCK TO THE BONE" CONCEPT ANYWAY, SO WHY NOT BUY A GOOD STRIPPER/CRIMPER, & GET YOURSELF A GOOD SET OF 8mm TAYLOR UNIVERSAL SPIRAL CORE WIRES, & MAKE THEM ANY LENGTH YOU WANT. BESIDES... IT'S KINDA HYPOCRITICAL TO PICK & CHOOSE WHAT MODERN OPTIONS ARE OK WHILE LOOKING DOWN YOU'RE NOSE AT OTHERS..... DONTCHA THINK
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-18-2003, 07:41 PM   #21
CPNE
Resident Curmudgeon
CPNE's Avatar
JYJ,
If you take the time to review everything I've ever commented on in the ongoing stock vs custom debate, 90% is done with irreverence and sarchasm, as was everything in this post. I have zero objections to making changes as one see's fit. I like the stock "look" as my preference but nowhere have I ever SERIOUSLY stated every nut, bolt, and screw need be correct or it's a sin, or for that matter, anyones preference contrary to mine is outright wrong (misguided yes <--SARCHASM). So I'm a little unclear as to why your comment is so hostile, unless it stems from the fact that my pitiful attempts at humor in the past have failed to stike you as I had intended. For that I apologise.
As for the crimpers, I've already picked up the 75 vette wire set for $18 at NAPA and if they don't route the way I want, I'll investigate that option.
Thanks and keep if FUN!
Stock-lite. Looks great, less trouble. I kinda like that.
Old 09-18-2003, 09:13 PM   #22
lukecp
Formerly yellow72custom
lukecp's Avatar
Nothing wrong with picking modern options on an original truck. Driving something with a 2-speed powerglide, manual brakes and steering, points, drum brakes, and bias-ply tires isn't really an enjoyable experince. I prefer trucks with some "esseintal" upgrades, but a still stock look
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-18-2003, 09:28 PM   #23
junkyardjohn
NAW JEFF -- DON'T TAKE MY RESPONCE AS HOSTILE . I ALWAYS TYPE IN ALL CAPS IF THATS WHAT GAVE YOU THE IDEA I WAS. ( I TEND TO TYPE LIKE OLD PEOPLE HAVE SEX. SLOW & SLOPPY) I ONLY TYPE WITH ONE FINGER ( 1/2 OF PICK & PECK) SHOOT I DIDN'T MEAN ANY OFFENSE, & I'M SORRY IF IT SOUNDED THAT WAY. I GOT THE HUMOR PART 100% & WAS JUST TRYING TO GIVE IT RIGHT BACK. I TEND TO GO INTO JUNKYARDS WITH A BATTERY OPERATED SAWZALL JUST INCASE I HAVE TO CUT MY WAY OUT
junkyardjohn
DON'T RENT U-HAUL
Old 09-18-2003, 09:32 PM   #24
CPNE
Resident Curmudgeon
CPNE's Avatar
Okay I feel stupid now. I wuz the one who missed the point.
Speaking of sawz-alls, I've been wielding one lately too. Replacing rusty rockers, cab corners, floors and supports, and pillars. Something you know nothing about
Old 09-19-2003, 10:15 AM   #25
palallin
I beg to differ: I enjoyed it quite a bit.
Nowadays I have a 4-speed instead of a PG, and I can't even find Bias-ply in my size, but manual, drum brakes are still de rigeur, and I have PS only because my current truck came that way.
Gotta keep in shape somehow!
:p
