Old 12-18-2015, 01:32 PM   #1
aotte1
Ball Joints should they be replaced?
Rebuilding '78 Dana 44, and forgot to check ball joints before removing axle from truck. Now with axle out they feel tight. Any recommendations on whether they should be replaced?
Steam cleaning axle once weather warms and going for powder coating soon.
Thanks for help,
Les
aotte1 is offline   Reply With Quote
Old 12-18-2015, 01:45 PM   #2
aotte1
Re: Ball Joints should they be replaced?
Just talked to my powder coated (PC) and they said, ball joints will need to be out to PC.
New Question if ball joints are ok , any issue with replacing with new ones?
Old 12-18-2015, 01:55 PM   #3
aotte1
Another option if not powder coating, is to ceramic coating, or liquid painting.
Still need to decide to replace BJs or not.
Les
Old 12-18-2015, 03:47 PM   #4
61K10
61K10's Avatar
Les--just do it now, as you have it apart. You're rebuilding everything else.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-19-2015, 09:17 AM   #5
andrewmp6
Yeah if i have to take them out i would replace them just because im already there.
andrewmp6 is offline   Reply With Quote
Old 12-19-2015, 10:02 AM   #6
ryanroo
ryanroo's Avatar
ill jump on that bandwagon too. its to important of a part and to easy to do it while apart not to just get some nice high quality replacements. then when the truck is together there wont be any ghosts floating around in your head.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-19-2015, 10:28 PM   #7
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Yes, better do it now.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-19-2015, 11:50 PM   #8
andrewmp6
And on the coating i would use just normal powder coating,The ceramic coating is more for things that see a lot of heat like headers or engine parts.
Old 12-21-2015, 10:41 AM   #9
aotte1
Thanks everybody for the help.
Les
