Old 12-18-2015, 08:36 PM   #1
scott657
scott657's Avatar
Help with upper control arms
Got new control arm shafts bushings an seals. The shaft moves freely side to side, and the seals are loose, do I need some spacers?also, which way do the seals install? small side in or out.
This is the part
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
scott657 is offline   Reply With Quote
Old 12-18-2015, 10:17 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Help with upper control arms
I did mine a couple of years ago and dont remember any issues with it. The pics of this in my build thread are not showing up.. At first I did one cap then the other and something was not quite right so I removed them and threaded them on evenly at the same time. that seemed to work better.
There should be no spacers needed.
If you PM me your email, I can send you the pics of mine.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-19-2015, 03:33 PM   #3
scott657
scott657's Avatar
New
Ok, I have them torqued to around 160 lb/ft cant move the shaft by hand, I can in the vise. There is still play with the rubber seal, I dont know if that matters in the grand scheme. I still can rotate the shaft in the vise to center the shaft in the arm.
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
Old 12-19-2015, 07:36 PM   #4
Captmatt
It's been a few years, but the rubber seals don't look right to me. I recall my seals were a little wider and had a step in them. Different diameters on each end for a tight fit on the shaft and the wide end facing the threads on the arm.
I recall my shafts also being tight when I reassembled, have not had any problems since
Captmatt is offline   Reply With Quote
Old 12-19-2015, 07:42 PM   #5
Captmatt
This is what I remembered....
