Old 12-18-2015, 09:59 PM   #1
aod92
aod92's Avatar
Maf Question?
what kind of mass air meters are you guys running? My motor is pretty much stock except for a cam, headers, and an intake. Do I just run a stock one, or aftermarket?
aod92 is offline   Reply With Quote
Old 12-18-2015, 11:17 PM   #2
Heavymetl
Re: Maf Question?
The stock truck MAF is 85mm, and is plenty given your description. Even if it's and F-body MAF the smaller unit should also be just fine and cause no restriction. (measurable loss of manifold pressure under WOT)
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 12-19-2015, 01:51 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Maf Question?
Just run a stocker. No reason to go with an aftermarket MAF unless you start getting into aftermarket-block levels of cubic sexiness, or want to run roots or screw blower.
The need for an aftermarket MAF is rare. Usually you need huge cubic inches in which the flow #'s will create a bottleneck at the MAF. This is usually only the case when your already running something like a Fast102/102 or a Fast/Nick Williams.
You may also need an aftermarket MAF due to bar scaling (stock is 1 bar). This would be the case if you were running a draw-through blower, or running a turbo setup with a MAF.
My opinion is that you run the stock MAF until it becomes a limitation, then just go SD.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-19-2015, 09:53 AM   #4
aod92
aod92's Avatar
Re: Maf Question?
Thanks for the help guys. I'm also running a 90mm throttle body. Will that make a difference on the maf size?
Old 12-19-2015, 10:19 AM   #5
aknovaman
Re: Maf Question?
Run the MAF that your PCM file is set up for. Unless you are turbo or supercharged, you will not max out the MAF flow and table settings. Larger MAF are one of the biggest waste of $$ out there.
Your tuner will be able to see what vehicle the PCM file is from when tuning and make a few minor adjustments for the throttle body.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
