![]() Join Date: Aug 2001
it smooths out once the rpms get up a little but it seems to hesitate a little at idle and while getting off idle. 400 miles on rebuild new hei, etc. edelbrock carb. just started yesterday. ideas? I have already checked wires, vacuum connections. hope its not a camshaft.
GEARHEAD
Could be several things, but I'd start with the carb. It could be hesitating because it's not getting enough fuel at acceleration. This could be the accelerator pump or just the cam size for the pump is to small. It could also be flooding on acceleration, but I'd lean to the not enough fuel.
Could also just be timing. Mine hesitates a bit when the engine is not completely warmed up. I don't have the choke hooked up. Once it's hot the problem goes away. HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
the stumble off idle is very slight. engine temp seems to have nothing to do with symptoms. the biggest thing is the irregular idle. seems to surge and/or miss almost like its going to stall.
CCRider
What size cam do you have? How many inches of vacuum are you pulling at idle.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
![]() Join Date: Sep 2001
What's your timing set at? You're using vacuum advance right?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
thanks for the replys guys.
camshaft is stock for a small journal 327. not sure of the exact specs. have not checked vacuum, however the only thing i have under vacuum is the advance and pcv. timiming is set about 8 btdc. |
