Old 12-19-2015, 04:06 PM   #1
stomper
Junior Member
stomper's Avatar
292 PS brackets question
Can these brackets be used without the air pump and not look like something is missing? If you know what I mean...
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 12-19-2015, 08:05 PM   #2
swamp rat
swamp rat's Avatar
Re: 292 PS brackets question
If you can remove the air pump and find a belt that will work there is no reason it wouldn't work unless there is something in the new short belt path, so if that works then you could probably modify the bracket by cutting it down.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-19-2015, 08:09 PM   #3
68panelman
68panelman's Avatar
You might be able to go to the crank pulley if you have a extra slot for the belt. My 70' 292 had double water, double alt pulleys, and a 4 belt crank pulley.
68panelman is offline   Reply With Quote
Old 12-19-2015, 08:11 PM   #4
68panelman
68panelman's Avatar
But that motor looks late 70's early 80's though
Old 12-22-2015, 05:02 AM   #5
stomper
Junior Member
stomper's Avatar
Yea it's in a 83 or 84 C20. I got the HEI off it.
