Old 12-19-2015, 06:49 PM   #1
akeane01
55 1st Series Rear Axle
hi,
I just started working on the C3100 truck rear suspension and noticed that the passenger side leaf spring perch has a metal block added for compensation. The drivers side does not have this. Was this normal to have? I would have thought that would not be needed if the truck was built correctly.. Any thoughts..
thanks
akeane01 is offline   Reply With Quote
Old 12-19-2015, 07:14 PM   #2
Virginian
Virginian's Avatar
Re: 55 1st Series Rear Axle
It is not normal both sides should be the same, it was put there by someone to compensate for something maybe truck sagging in that corner due to something bent/twisted.
Virginian is offline   Reply With Quote
Old 12-19-2015, 07:37 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
This was commonly done at the dealer or at the factory, not sure which,to level the bed/bumper. They did it in the front as well. I see these blocks alot
dwcsr is offline   Reply With Quote
Old 12-19-2015, 08:10 PM   #4
Virginian
Virginian's Avatar
Could be, those 1950's assembly lines were not high tech.
Old 12-20-2015, 02:12 PM   #5
greg_h
It was to offset the weight of the side mount spare tire on the driver's side so they put shim in pass side to even it out.
greg_h is offline   Reply With Quote
Old 12-20-2015, 09:02 PM   #6
_Ogre
_Ogre's Avatar
this may be true for the 47-55.1 trucks with the axle under the springs
because... any 55.2 to 59 truck (axle over springs) with the side mounted spare has the oem shim on the drivers side
see 55-59 fam, rpo 341, sheet 1.00 (near the back of fam)
shop air compressor timer
Old 12-21-2015, 12:58 PM   #7
greg_h
Then that would make sense. If it has the opposite effect due to the positioning of the leaf springs above or below the rear axle, then it would go to the opposite side to have the same effect....Still it is because of the side mount spare tire weight. That's my story and I'm sticking to it!
Old 12-21-2015, 02:15 PM   #8
mr48chev
mr48chev's Avatar
Both scenarios are viable. It could have been added to compensate for the weight of the side mount spare or it could have been added later to "level" the truck when it looked like that corner sagged a bit.
A few years ago I got pulled over by a deputy sheriff and while talking to me he commented that the left side of my truck sagged a bit. My answer was "fat driver" as I weighed about 250 at that time and for some reason he didn't like my answer even though it was the truth as I normally was alone in the truck going down the road.
My ongoing truck projects:
Old 12-21-2015, 07:00 PM   #9
_Ogre
_Ogre's Avatar
because... any 55.2 to 59 truck (axle over springs) has the oem shim on the drivers side
i should have added ''with the side mounted spare''
