cab swap
ok guys. this is what i got going on now.
i am going to be recabing my roll back. i have found a cab for a good price. problem is its a 2wd auto cab. my truck is a 2wd standerd cab. so ? is what needs to be done to get the hydro clutch peddles and master in and can i just cut a hole in the floor for the shifter?
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
Re: cab swap
Most cabs have dimples to drill the holes for the clutch and it should have a indent for the shifter hole as long as it's close to the year for hydraulic clutch
Re: cab swap
if its 85 and up it should have the dimple on the firewall for the clutch master, and if your old cab has a good hump (high hump)where the shifter is ,cut it loose to use it on your auto. cab
1981 c30 dually, 350 sm465 ex tow truck now yard mule 1985 k35 dually, 454 th400 np205 1985 D30 cucv M1008, 6.2 th400 np208 1999 toyota tacoma, lifted 6'' 31'' tires 2003 toyota echo, reliable and damn cheap on gaz |
Re: cab swap
something good on the old cab???? hahahaha your funny. is there anything else that you guys have run into doing this? tips and tricks things i should look for? thanks, mike
Re: cab swap
Are the trans tunnel hump the same on them?
Re: cab swap
do you have pictures of your tow truck?
Re: cab swap
manual and auto 4x4 have high hump while auto 2wd have small hump
Re: cab swap
You may find your SM465 hitting the floor on the low hump 2WD cab. And the late model cabs the floor is one piece, no bolt on hump.
Re: cab swap
well i thought i had a cab. deal fell apart. witch right now is ok with me. money is tight. pic should be in this post........if i did it right..... lol merry xmas
Re: cab swap
cool truck does it have a wheel lift at the back?
![]() Join Date: Feb 2013
Re: cab swap
Your need a high hump cab, or you could replace the tunnel if you can find a good high tunnel to swap into a low tunnel cab, I have done it, but it was not pretty, but if you take your time it can be done to look OE. Best bet is to find a hi tunnel cab, manual 2wd, or most 4x4s. If you end up needing a hi hump, look for a 4x4 suburban from 85-91 and cut the tunnel out of that, better chance of finding a decent tunnel, and it will work for a 2 door cab.
Nice truck, what bed is that? Here is mine, 1987 R30, with a Century Bed.
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 Last edited by SamsAutoParts73-87; 12-26-2015 at 01:46 PM. |
Re: cab swap
nice truck!!
#13 |
Re: cab swap
thanks
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
#14 |
Re: cab swap
its a Century Bed also...... i think. or jerrydan 78 i do know that. has non hydro wheel lift out back but i dont use it at all.
love this truck. how many springs does your trucks have in the back? mine has 14 with a 4 overload pack
#15 |
Re: cab swap
mine has 11, plus the overload.
-Sam
#16 |
Re: cab swap
You might be able to get away with a bit of a body lift rather than hacking the floor up.
1973 C20, 350/350 |
