Old 12-19-2015, 11:17 PM   #1
tismy65
52" leaf Springs
I'm using a 3/4 ton Front & Rear Axle ,The front Has 52" Leaf Springs I need to know is this the right direction for the springs ? Or does that flip looking spring go to the front hanger ? Thanks for any help.
tismy65 is offline   Reply With Quote
Old 12-20-2015, 12:41 AM   #2
Captainfab
60-66 Nut
Re: 52" leaf Springs
I don't remember for sure. What have you done for the front spring hanger? You might get a better response if you ask a mod to move this to the "4x4 Tech & Offroading" section.
Old 12-20-2015, 08:28 PM   #3
argonaut
argonaut's Avatar
Are you sure that those are 52" front springs? They sure do look like 47" Springs to me. Anyway, the shackle angle looks okay now, but when you load the frame with the motor and sheet metal it may be a little too much. You'll just have to wait and see. Oh, and you are correct, you need to flip the springs around. The double wrap part goes on the front hanger.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 12-20-2015, 11:21 PM   #4
tismy65
They came with the 90 3/4 ton 8 lug front & rear axles I purchased Fronts measured 52" Rears measured 56" I moved them around and that flip hit the top of the hanger and would not line up to install the bolt. but the way I have them in the picture bolts right in.
Old 12-20-2015, 11:28 PM   #5
argonaut
argonaut's Avatar
That's because early front hangers don't have enough clearance for the wrapped leaf. The way you have them now the end of the leaf is going to hit the bottom of the frame once you out weight on it and hit a bump. At least that's how it looks in the picture.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 12-21-2015, 01:00 AM   #6
tismy65
Will the Earlier leaf springs fit the perches on the 90 axle, or should I change the front hangers with 88-91 front hangers.Thanks for suggestions.
