Old 12-20-2015, 12:27 AM   #1
REEDS 72
REEDS 72's Avatar
Brake booster question
I need to put a smaller booster in my 72 for clearance reasons. The booster that I am going to use, there is only a threaded rod. My question is, what are you guys using to connect it to the brackets on the firewall? Any help will be greatly appreciated, pictures will also help.
REEDS 72 is offline   Reply With Quote
Old 12-20-2015, 10:14 AM   #2
Mike C
Mike C's Avatar
Re: Brake booster question
You can fab brackets and connectors or whatever it takes, but $200 and a couple of minutes on eBay will get one delivered to you that has correct brackets, connection to the pedal, master cylinder and proportioning valve.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-20-2015, 10:33 AM   #3
hugger6933
Have you looked to see if the clevis on the OE stuff is threaded to use on there? It should be.
hugger6933 is offline   Reply With Quote
Old 12-20-2015, 11:33 AM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
This the one you are talking about. I've been looking at this for my truck.
http://www.ebay.com/itm/331727866741...%3AMEBIDX%3AIT
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-20-2015, 11:49 AM   #5
REEDS 72
REEDS 72's Avatar
Yes my booster is just like the one in the picture I just need that threaded clevis.
Old 12-20-2015, 11:55 AM   #6
REEDS 72
REEDS 72's Avatar
No it does not come off but thats what I need is a threaded clevis.
Old 12-20-2015, 01:03 PM   #7
tcrist
You might try http://vintagechevytrucks.com/ . They are like a wrecking yard for these trucks. I bought a complete OEM setup from them to convert mine to power brakes.
There web site is still screwy but the contact information is there.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 12-20-2015, 09:20 PM   #8
Mike C
Mike C's Avatar
That's it. Not sure if it's the same seller but that's the idea.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-20-2015, 11:31 PM   #9
REEDS 72
REEDS 72's Avatar
Thanks for your help but I do not need the whole unit I only need the clevis that screws on the end of the threaded rod coming out of the back of the booster. Can anyone help me find one or direct me on where to go looking.
Old 12-21-2015, 01:54 AM   #10
Lattimer
Lattimer's Avatar
I cut the end off the stock one and welded it to the rod on the new smaller booster I used. Worked like a charm.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-21-2015, 11:03 AM   #11
67 chevelle
67 chevelle's Avatar
http://www.ebay.com/itm/Allstar-Perf...VWamGh&vxp=mtr
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
