Old 12-20-2015, 03:21 PM   #1
Fountain
Rear suspension
I have 1953 Chevy truck and I am debating what rear suspension to use. I would the truck sit low with a static drop. Up front will be a danforth crossmember with drop spindles. It is notched into the frame to drop an additional 1" or so. It will be 4-5 drop up front. I am looking for a level rake.
Would the leaf spring kit from TCI with blocks provide enough to drop to make it level? Has anyone used the ride tech 4 link triangulated rear kit? I am also considering what Dave from Hollister did with the trailing arm kit from Classic.
Any help would be appreciated.
Fountain is offline   Reply With Quote
Old 12-20-2015, 04:44 PM   #2
Sim6
Sim6's Avatar
Re: Rear suspension
IMO, a flip kit with 2 or 3" blocks would level it out. Do you still have factory leaf springs and axle? I'm sure someone with with more OG frame expertise will jump in.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 12-20-2015, 05:04 PM   #3
Fountain
Re: Rear suspension
I do not have the leaf springs or rear differential
Old 12-20-2015, 07:10 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Rear suspension
The TCI leaf spring kit is going to be a bolt on with welding on the axle perches, The trailing arm fab required was making some extension plates for the cross member and the coil spring mounts, and the spring perches the rest was bolt in. You could use coil over shocks to get past the coil spring mounts,
TCI also has a 4 bar with coil overs that's a bolt in. It lowers the rear 4"
Any of these would get you down lower. you will have to play with any of them to get where you want to be.
dwcsr is offline   Reply With Quote
Old 12-27-2015, 07:49 PM   #5
Fountain
Re: Rear suspension
I have decided to go with the trailing arms like Dave did, I have also decided to bag it. I am already there, bare frame, might as well. Thanks Dave for your help. Should have the Danforth Cross member installed tomorrow, I hope.
Old 12-28-2015, 12:04 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Rear suspension
I think you'll be happy with that choice
Old 12-28-2015, 11:31 AM   #7
jweb
jweb's Avatar
Re: Rear suspension
If you want a trailing arm suspension you can buy a kit from No Limit that bolts in. No fab work and includes everything you need. That's what I'm going to use as soon as I have the cash.
It's only around $350 more (with your forum member 10% discount) than the ECE kit and includes bags.
jweb is offline   Reply With Quote
Old 12-28-2015, 12:34 PM   #8
Coach529
Coach529's Avatar
Re: Rear suspension
Start a build thread......we would love to follow along.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 12-28-2015, 06:02 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Rear suspension
I haven't seen it on their site, Do you have a link?
