Old 12-20-2015, 04:55 PM   #1
7tee
7tee's Avatar
Left side window...
After rolling down about a 1/2" the window will bind making it hard for a short distance, then it will be normal the rest of the way. Does this sound like he regulator is going bad or could it just be needing some kind of adjustment? Thanks Ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 12-20-2015, 04:58 PM   #2
davepl
davepl's Avatar
Re: Left side window...
Bind going back up or bind going down?
On mine the little silver strip that runs the length of the inside of the window slot opening in the door has too much gap between it and the door and causes this binding the last 1/4" of the way up. Could be part of yours, as that's where it causes the "squeeze".
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-20-2015, 05:38 PM   #3
67swb72klb
67swb72klb's Avatar
Lube everything up good and don't forget the spring on the regulator even if it is wore out you can get them to work good
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-20-2015, 05:47 PM   #4
hugger6933
It is the regulator. Lube it up good with something that will last like a white lithium spray grease. Don't forget to lube up the channels where the glass rides also. You can use some silicone lube for those. you will be surprised how much better it will be. you can stave off regulator replacement by years just doing those little things. You will have to remove the door panel though. While at it lube up the door latch as well as the hinges. Here is the bonus free tip if you have never taken off a door panel, when using the door panel tool the fork portion [the V or whatever it should be called]will need to go in in line with the roller, you know the part where you put your hand to crank. All handles a cut in such a way the key goes in them all the same and if you put the tool in that way it will pop out the clip in a second or two instead of trying to search for the groove. Good luck and have fun. Jim
hugger6933 is offline   Reply With Quote
Old 12-21-2015, 03:06 AM   #5
XwalkerX
my truck is doing the same thing but for $30 i just bought a regulator
XwalkerX is offline   Reply With Quote
Old 12-21-2015, 08:40 AM   #6
7tee
7tee's Avatar
Thanks for the reply's.
Mine does it on the way down. I'll remove the door panel and try the above suggestions. I hope it's not the regulator...
2010 Acura RL...
Old 12-21-2015, 04:50 PM   #7
7tee
7tee's Avatar
After trying to adjust the window to no avail I silicone the tracks and greased the regulator and this helped quite a bit. It sounds like the bearings in the handle arm are going away as it clicks and rattles while raising and lowering so it sounds as though a new regulator will be my next choice...ed
2010 Acura RL...
