12-20-2015, 05:04 PM | #1 |
4" drop axle
hello i have a 4" drop axle on a 1950 gmc truck can anyone tell me shock length needed and good brand of shock they have used
12-20-2015, 07:16 PM | #2 |
Hollister Road Co.
Re: 4" drop axle
Should be the stock shock length. look it up on rockauto.com
12-20-2015, 07:19 PM | #3 |
Re: 4" drop axle
Yep, the shock length doesn't change with a dropped axle. The axle is in the same spot it was before it was dropped in relation to the frame it's just 4 inches closer to the ground.
12-20-2015, 08:39 PM | #4 |
Re: 4" drop axle
thanks for replys so when i look at the POL catalog for instance they list a shock for a 3-4" drop is that more for a mustang II front end
12-20-2015, 08:57 PM | #5 |
Hollister Road Co.
Re: 4" drop axle
Yes Mustang, S10 any suspension that uses A frames and coil springs to drop the vehicle. The drop axle your just stretching the spindle end upward and leaving the spring to axle distance alone.
12-20-2015, 09:32 PM | #6 |
Re: 4" drop axle
thank you
