Old 12-20-2015, 06:13 PM   #1
Mrturner1
Got my first advanced timing light, need tips
I got a timing light that has a dial on the back for timing, and I've never timed a vehicle before so I have NO idea what I'm doing but I wanna learn and tune on my own. No idea what it's set at now and I'm putting on the new edelbrock 650 carb at the moment. Any help is greatly appreciated
Mrturner1 is offline   Reply With Quote
Old 12-20-2015, 07:09 PM   #2
68 P.O.S.
Re: Got my first advanced timing light, need tips
Check this out: http://67-72chevytrucks.com/vboard/s...d.php?t=274806
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-24-2015, 11:16 PM   #3
Mrturner1
Do 350's tend to run better with certain timing set? Do aftermarket parts make a difference in what the timing should be? And is it as simple as pointing the light at the harmonic damper?
Old 12-25-2015, 12:15 AM   #4
4 Wheelin Fudpucker
4 Wheelin Fudpucker's Avatar
If you have points you need a dwell meter, that might be what the dial is.
need pic
Happy as a pig in mud
4 Wheelin Fudpucker is offline   Reply With Quote
Old 12-25-2015, 12:34 AM   #5
Benny-
That link has a lot of good info. The timing mark on the harmonic balancer could be painted to make it easier to see. Make sure your vacuum advance is connected to the passenger side port on the front of the carb. A good starting point would be around 6 or so degrees BTDC at idle and 34 ish at around 3k rpms. If timing is off the distributer must be twisted to change the timing.
1972 C/10 Cheyenne, Daily Driver. SOLD
1978 GMC K15 High Sierra.
Benny- is offline   Reply With Quote
Old 12-25-2015, 12:38 AM   #6
Benny-
I might add, the knob in the timing light makes it so you can find your advance while constantly having the timing mark hit "0". So if the knob is at say 12 and the mark is hitting zero, you're at 12 deg BTDC. Turn the knob at a given rpm til the mark hits zero and that is where your timing is. Set the knob to a degree you'd like to be at and see where the mark falls to know which way to turn the distributer. Just play around with it some.
