12-20-2015, 10:53 PM | #1 |
Window frames 48-52
I have 48 doors mounted. I do have a set of 52 door window frames, but they leave a huge gap (other than space for vent latch). Is the 47-50 window frames thinner than the 51-54's or is there a way they need to mount.
I do have new run channel. Thanks |
12-21-2015, 01:01 AM | #2 |
Re: Window frames 48-52
It's too cold, dark and late to go out and dig one of each out of the shed but from what I've read there are noticeable differences in them beside the notch for the vent wing
12-21-2015, 01:40 AM | #3 |
Maybe tomorrow you could compare. I hate to buy on ebay w/o knowing the difference as it looks like people sell NOT knowing any difference.
Thanks |
12-21-2015, 01:40 AM | #4 |
Hollister Road Co.
if you use a 48 door you need to use 48 windows and parts. The 47-50 uses a window frame around the glass so it thicker, The 51 up does not use a metal frame so the channel runner is narrower
12-21-2015, 01:48 AM | #5 |
I have 47-50 doors mounted with the stock parts. I can only now assume those window frames are somewhat thinner than the 51+
12-21-2015, 01:56 AM | #6 |
Hollister Road Co.
51 up has no window frame on the glass or are you talking about the outer molding that snaps on and inner molding that screw to the door. 47 -50 and 51 up do not interchange
12-21-2015, 02:10 AM | #7 |
I'm referring to the metal frame that screws on.
12-21-2015, 05:28 AM | #8 |
Hollister Road Co.
That's also different
12-24-2015, 12:19 AM | #9 |
I was able to check those frames tonight, they are identical outside of the cut away you see to clear the vent window framing, and the one hole you can see on the vent window one (pink.)
Now if I can find the outside window frames I know I had! Darn it, the only pair I found are pretty funky and I want to fix them nice enough for chrome. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
12-24-2015, 02:15 AM | #10 |
Thanks fir tge 8nfo from all. In the end, my problem was simple. I bought a pair of 47-50 window frames and all is well. Niw I will list my 51-54 doors for sale.
