Old 12-21-2015, 11:59 PM   #1
68Stepbed
68Stepbed's Avatar
4/6 or 5/7 drop with 26" tires
OK, I've spent the last 1 1/2 hours searching the boards and still haven't found what I'm looking for. Does anyone have a truck(stepside preferrably) with a 4/6 or 5/7 drop and about a 26" tire? Everything I've found seems to have between 27-29" tires. I'm curious to see if a shorter tire will look goofy or not.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-22-2015, 12:41 AM   #2
Malamute
Malamute's Avatar
Re: 4/6 or 5/7 drop with 26" tires
These are 255/60/15 which measure pretty close to 26". ECE 4.5/6 drop. I need new tires, I will be putting 275/60/15 on the rear and keeping the current size up front.
Malamute is offline   Reply With Quote
Old 12-22-2015, 08:10 AM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Here ya go.
245/40/18's, 335/30/18's - probably close to the tire size you're actually wanting to run if I remember your previous threads correctly.
First pic is when I mocked up before paint with a 4.5/6 drop. The other two are a 5.5/7.5 drop.
In the last pic, the rear wheels look weird and are tucked too much because I had my rear axle housing narrowed to fit the Schott wheels that I'm running now. I just threw the Boss wheels back on to get an alignment so my other wheels wouldn't get scratched up.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-22-2015, 09:31 AM   #4
midniteblues
midniteblues's Avatar
Ece 4/6 with 1 3/8" block. 235/75/15 thinkin they are 28" tall
With laying frame one can pull off the short tire look. But once you start getting a big gap between the tire and fender they look kinda "off".
I was hoping the weight of the bb would bring the front down a lil' more but it didnt.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-22-2015, 12:17 PM   #5
RustyBucket
RustyBucket's Avatar
255/60/15 ... 26" tall. not sure about the exact amt. of drop though. 2.5 spindles w/ 1 coil cut on the front and 4" springs (ebay cheap) rear w/1" block. I need rear titres too, trying to decide if I'll buy 275's.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 12-22-2015, 05:50 PM   #6
68Stepbed
68Stepbed's Avatar
I'm thinking of trying to stay on the cheap and buy new tires for the 17's I currently have, but I can only find tires in the 25-26" range. I'm thinking about running a Continental ExtremeContact DW in 255/45/17 front, 285/40/17 rear. Both are right at 26" tall. My current drop is 4.5/6.75.
Matt
Old 12-22-2015, 06:22 PM   #7
CC69Rat
CC69Rat's Avatar
Matt -- I'd be careful on the scrub line in the rear. Do you have OE trailing arms on the truck now or tubular?
I cant remember how your truck is dropped, are you using blocks in the back or drop springs? Have your shocks been relocated?
http://www.nolimit.net/tech-center/6...on-kit-1963-72
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-22-2015, 06:46 PM   #8
Ekliptix
Ekliptix's Avatar
Not sure of the tire height, but tires are 275/60/15 all around. Drop is ECE 4.5/6.25.
Ekliptix is offline   Reply With Quote
Old 12-22-2015, 06:47 PM   #9
68Stepbed
68Stepbed's Avatar
6" Hotchkis rear spring with 3/4" drop block. OE trailing arms with ECE shock brackets. Basically stock location, but more upright.
I can't currently use the NoLimit shock brackets because my fuel pump is mounted where the brackets would mount.
I'm basically just wanting to put lower profile tires on my current 17" wheels.
Matt
Old 12-22-2015, 07:18 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
The only 17's I ever bought were for 17x8's and 17x9.5's.
They were Nitto NT450 tires.
I had 255/50-17's and 275/50-17's.
They didn't look small at all and were very affordable.
http://www.nittotire.com/passenger-t...formance-tire/
Keith
Convert to disc brakes.
Old 12-22-2015, 07:35 PM   #11
Mike C
Mike C's Avatar
Great looking truck. The 275 60 15 is a 28" tall tire. The reason you see few 26" tall tires is the wheel well is just too large IMO. I went out of my way to get taller tires. Dropped the truck 4.5"/7" and did 235 55 17 in front for 27" tall tire and 275 55 17 rear for 29" tall tire.
Wheel tire choice is subjective and personal, but almost universally the taller tires make for a better looking truck IMO. But once again that's just an opinion...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-23-2015, 09:52 AM   #12
68Stepbed
68Stepbed's Avatar
I really didn't go into detail on this. The past couple years, I've geared more toward the autocross route with my truck. I actually haven't entered the truck in a car show in almost two years. Eventually, I'll go 18's so I'll have better tire choices. I want to wait until I can do more to the truck, though before ordering the wheels I really want. I hate to spend the money for custom wheels to fit my current setup, then change parts that require different offsets, then have wheels that don't fit. So, for the time being, I want a tire that's more performance oriented to autocross or grip. That being the case, there's not any tires in the 17" range larger than 26" tall.
If I were just keeping the truck as a cruiser/show truck, I'd go with the Nitto NT450. It's hard to beat that size on these trucks. They're just the kind of tires I want for what I intend to do with the truck.
Matt
Old 12-26-2015, 02:01 AM   #13
68Stepbed
68Stepbed's Avatar
ttt Anyone else have any input?
Matt
Old 12-26-2015, 03:12 PM   #14
XwalkerX
your truck looks FANTASTIC
XwalkerX is offline   Reply With Quote
Old 12-26-2015, 04:38 PM   #15
72MARIO
72MARIO's Avatar
I don't know how the 275 60 15 do not rub on the front of that truck^^^^^^^^^^^^ I have always found it necessary to used van 6.5 rims and a skinny tire to prevent rubbing
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
