Old 12-22-2015, 09:03 AM   #1
chincha805
lowering 49 S10
i want to lower my pickup at least 3-4 inches in the front and 4-5 in back, what are the best ways to do this with spindles and springs,
chincha805 is offline   Reply With Quote
Old 12-22-2015, 10:15 AM   #2
joedoh
joedoh's Avatar
Re: lowering 49 S10
s10 frame? easy peasy, 2" drop spindles and 2" coils in the front. in the back use 2" drop leaves and 3" blocks, you will need angled clocks or pinion angle shims to realign the driveshaft with that much drop.
dont forget new shocks or you will lose your fillings.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-22-2015, 10:16 AM   #3
rtinniste
Re: lowering 49 S10
Yea 2" drop spindles and 3" drop springs for the rear I'd recommend 4" lowering leafs and maybe a 1-2" block something about 4" and up blocks seems sketch your putting added leverage and strain on the u bolts. People do it tho depends on what your budget is. Over 4" drop in the rear you might need a bolt in c notch i know my frame sitting in the garage has 9" from axle to frame on stock suspension not sure how much there would be with a body and a full tank of gas now take out 5" from that now you only have 4" of bump travel. The notch will net you about 2-3" inches of travel
You would just need lowering spindles new run about 150 on ebay.
lowering springs
http://www.belltech.com/products/bel...its-15230.html
bolt in c notch
http://*************/notches/bolt-c-notch-kit
rtinniste is offline   Reply With Quote
