![]() Join Date: Mar 2012
new shocks ???
how do you know when it is time to replace the shocks,
I replaced the front shocks about 6 years ago with just a standard set of gas shocks, and installed a set of Gabriel air shocks on the rear, wondering if it is time to replace the fronts again, when I bought the truck 6 years ago, the old ones I took off did not even move they where seized up
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
motor exploder
Re: new shocks ???
Is the front really 'bouncy'? Meaning does it continue to oscillate after you go over a bump? If so, it's definitely time. If you care to take one off, set on end on the ground and push down on it - it should be pretty hard to push down and should come back up smoothly and fairly quick. If it pushes in really easy and/or stays in after you push it, it's done. Is there any oil around the piston or seal?
I'm sure others will chime in with more/better experience, this is just my redneck shadetree mechanic way of checking.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() Use the SEARCH function on this forum - it is your friend!! |
| Bookmarks |
