Cowl removal
I want to take the cowl off to check the fresh air door while I have the ac out. Can it be removed with the fenders on? I see a bolt on either side and some small Phillips head screws. I also realize the wiper arms will have to come off. It looks pretty straight forward is there anything I'm missing or not seeing?
I figure it is the right thing to do since the door and it's sealing gasket are 45 years old. Thanks Keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Roadtrip!
![]() Join Date: Feb 2003
Re: Cowl removal
Pretty straight forward. Fenders can stay on.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Old member
Two bolts on each side of the truck. Then the wipers and the front P/H screws anntenia if you have one. Prett simple. Be carefull lifting it off the truck don't scratch it. Best to have someone helping you.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Cowl removal
Like mentioned pretty straight forward but it helps to have 2 people as they tend to want to scratch the A Pillar when comming off.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Cowl removal
Pulling the wipers without scratching the cowl can sometimes be tricky. A wiper puller (purchased or homemade) is essential.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
Re: Cowl removal
Most auto parts stores will carry this arm removal tool from Lisle
http://www.sears.com/lisle-windshiel...4&blockType=G4
