Old 12-23-2015, 02:28 PM   #1
duramaxguy
'70 C20 variations
Hi Gang -
I know this info is on the board somewhere, but I am not able to find it. I'm scouring the earth for a '70 C20 and would like to know what the factory variations were for this model. Engine/trans combos, trim packages, etc. Both 2wd and 4wd. I want to be able to spot originals and rigs that have been pieced together.
Thanks for any info or links you can provide.
Kyle
duramaxguy is offline   Reply With Quote
Old 12-23-2015, 02:34 PM   #2
68350
68350's Avatar
Re: '70 C20 variations
From packages were base (c20 emblem), custom comfort and convenience (custom20 emblem) and custom sport truck (cst20 emblem). Any of these packages could be ordered with the custom camper nameplate (customcamper 20 emblem). Engines available were 250,292,307,350, and 402. 250 and 307 didn't have engine emblems below the c20 emblem as they were standard and not optional. The 402 was not available in the 4wd models. 3 speed manual, 4 speed manual, powerglide, and turbo hydramatic were available for transmission. In one ton applications the 3 speed manual was not available. I don't know if the powerglide was available in one tons. Powerglide wasn't available in 4wd either. I hope that covers it
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-24-2015, 09:51 AM   #3
duramaxguy
This guy is claiming to have a stock 396 in a '70 C20 4x4
Link
Did this come from the factory or did someone build it?
Old 12-24-2015, 11:08 AM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
No big blocks came in 4x4s. That truck has obviously had things done to it. Even the emblems are in the wrong spots.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-24-2015, 05:13 PM   #5
franken
You might consider 71 since that's the 1st year for disks...
franken is offline   Reply With Quote
Old 12-24-2015, 08:34 PM   #6
jocko
jocko's Avatar
If the VIN on the 70 starts with a K, it's likely an engine swap (big block into an original small block 4x4 - and as mentioned above, bbc never came in 4x4). If it starts with a C, it's likely a frame swap (from 2 to 4wd). The latter is more common.
Old 12-27-2015, 12:11 AM   #7
duramaxguy
Any comments on this one:
http://spokane.craigslist.org/cto/5347087926.html#
I'm looking for a 3/4 ton 4x4 4spd as the base for a restoration. not going to build a show truck. Just a high-end daily driver. I don't mind doing rust repairs, or might even swap out the body entirely. I want to start with something that is as close to original equipment as possible and keep it that way. i've asked the seller for the VIN and build plate so that I can see if the rig has been modified. Based on the condition of the body, I doubt it.
Anything in particular I should be looking at?
