Old 12-23-2015, 09:48 PM   #1
Jraney
64 c10
Hey folks I have a frame that isn't the original for my truck. Can anybody give me some ideas on how I can identify it. So I know what to buy as far as front end parts go. Thanks
Jraney is offline   Reply With Quote
Old 12-23-2015, 10:57 PM   #2
NevEno
NevEno's Avatar
Re: 64 c10
Pictures?
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 12-24-2015, 12:42 AM   #3
Jraney
Originally Posted by NevEno View Post
Pictures?
I will try to get some up tomorrow. Thanks.
Old 12-24-2015, 12:54 PM   #4
Jraney
Here's what I have. It's an x frame with 115" wheel base.
I have googled gm vehicles with that wheel base and gm x frame vehicles. All I could find was possibly a 64-67 chevelle.
Old 12-24-2015, 01:03 PM   #5
Jraney
Old 12-24-2015, 01:04 PM   #6
Jraney
Re: 64 c10
Hopefully those pics help.
Old 12-24-2015, 01:34 PM   #7
NevEno
NevEno's Avatar
Re: 64 c10
Maybe this will help. 60-62. Where are you in Oklahoma?
http://67-72chevytrucks.com/vboard/s...d.php?t=507893
Old 12-25-2015, 12:37 AM   #8
Captainfab
60-66 Nut
Re: 64 c10
That is a '60-'62 frame, possible a GMC frame with the leaf springs in the back. It also has a later model coil spring front suspension. The front suspension, could be a '71-'72, but I can not see enough of it to be able to tell. But then again, considering the hodge podge of parts, it really could be a mix of several different parts. Are you sure that the cab is a '64?
Old 12-25-2015, 12:39 AM   #9
Jraney
Re: 64 c10
Ok how do I identify the front suspension so I know what parts to buy if I need to replace anything.
Old 12-25-2015, 12:46 AM   #10
Captainfab
60-66 Nut
Re: 64 c10
A pic of the dust shield may help. Like I said, considering the rest of the truck, if it does have a '64 cab, the front could be a mix of who knows what.
Old 12-25-2015, 12:49 AM   #11
Jraney
Re: 64 c10
The way it was explained to me when I got it was it was a donor frame with a 60 Chevy cab. That can wasn't as good as the 64 I have so off it came. Where is the dust sheild you speak of.
Old 12-25-2015, 12:52 AM   #12
NevEno
NevEno's Avatar
Re: 64 c10
Is it a short bed?
Old 12-25-2015, 12:56 AM   #13
Captainfab
60-66 Nut
Re: 64 c10
So when you got this frame, it had a '60 cab on it? Why are you wanting to use this frame with your '64 Cab? Do you not have the '64 frame? That is a much better frame to use IMO. Have you checked with your local DMV to find out what is needed to make a frame/cab swap legal? The dust shields are on the back side of the spindles.
Old 12-25-2015, 06:39 AM   #14
Jraney
Re: 64 c10
Yes the frame is for a short bed. My 64 was a long bed. No I've not checked with the dmv. This front end on this frame has disc brakes. Another reason for the swap.
Old 12-25-2015, 11:52 PM   #15
Captainfab
60-66 Nut
Re: 64 c10
All of the disc brake components should bolt right up to your '64 frame whether you just bolt up the spindles or the entire suspension. crossmember and all. If you are wanting a shortbed, I would just shorten your '64 frame. You will have a much better and easier to work with frame that way. Plus no issues with having a cab that has a different VIN than the frame. I wouldn't bother with making that '60 frame work with your '64 body. It isn't a bolt on deal anyway.
Old 12-26-2015, 12:10 AM   #16
frankslagoon
Re: 64 c10
Like the Captn said the cab mounts are different between 60 and 64, just to begin with
frankslagoon is offline   Reply With Quote
Old 12-26-2015, 12:25 AM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 64 c10
Keep the 64 cab on the frame it belongs to.
Roll out the whole crossmember with the discs and bolt it up to the 64.
66 C20 Service Truck:
Old 12-28-2015, 10:15 PM   #18
Jraney
Re: 64 c10
Very interesting. Thanks for the info. Y'all say the front end parts will all interchange. I'm worried I will have trouble with that part.
Old 12-29-2015, 01:57 AM   #19
Captainfab
60-66 Nut
Re: 64 c10
The entire front suspension, crossmember and all will bolt up under your '64 frame. Or you can just change the balljoints on your '64 upper and lower control arms and bolt the disc brake spindles on. There are several threads on this in the 60-'66 FAQ section at the top of the page. Upgrading to front disc brakes on the '63-'70 trucks is very simple and easy to do with '71-'87 factory parts. It is a whole lot easier than messing with putting your '64 body onto that '60-'62 frame.
Old 12-29-2015, 02:05 PM   #20
Jraney
Re: 64 c10
I know it would be best to have my original frame but I swapped it for some other parts I needed. Anyhow I can probly get a 65 short bed frame. Will that bolt right up to my 64 cab?
Old 12-29-2015, 04:13 PM   #21
NevEno
NevEno's Avatar
Re: 64 c10
I would get the 65 frame it would be a lot better set up! The only difference in the 64 and 65 frames is the trac-bar mount.. The one on the 65 is better IMO with more options as far as aftermarket Trac-bars..I too live in Oklahoma and have bought several vehicles from Texas and the dmv has never once checked the frames for matching vin numbers. If you sell it to someone out of state it might be a different story.
Old 12-29-2015, 06:40 PM   #22
Jraney
Re: 64 c10
NevEno , what part of Oklahoma do you live in? I'm east of Ada for now.
Old 12-29-2015, 06:44 PM   #23
NevEno
NevEno's Avatar
Re: 64 c10
Ada
Old 12-29-2015, 06:47 PM   #24
Jraney
Re: 64 c10
Really. Small world.
Old 12-29-2015, 06:49 PM   #25
Jraney
Re: 64 c10
You have any pics of your truck?
