Old 12-24-2015, 05:34 PM   #1
Smith & Sons
1969 Help please -C20 Rear end change
Have a 69 C20 with an 8 lug ,4.10 diff & truck arms,lowered 5 1/2".Looking for ideas to change to a 3.50 ratio,8 or 6 lug.I see a lot of 3.73 ratios in the trucks,ideas please.
Smith & Sons is offline   Reply With Quote
Old 12-24-2015, 05:38 PM   #2
Clavo106
Re: 1969 Help please -C20 Rear end change
so you are trying to go 3/4 ton to 1/2 ton.?
Clavo106 is offline   Reply With Quote
Old 12-24-2015, 10:46 PM   #3
Mike C
Mike C's Avatar
You can get 3.23 or 3.42 gears in either the FF or SF GM 14 bolts, but 3.73 is by far the most common in either flavor. You can relatively easily get 3.54 in a Dana 60 but not super easy to find in the coil sprung variety and obviously either of the 14's requires welding.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-25-2015, 08:17 PM   #4
Smith & Sons
Would prefer to keep it a 3/4 ton & locate a bolt in replacement with a taller gear.
Old 12-25-2015, 08:21 PM   #5
Smith & Sons
Thanks Mike. just had the TH400 built up & was hoping to avoid the expense of a Gear Vendors.Wanted something I could pound on,so my tranny man said to stay with a 3 speed.
Old 12-25-2015, 08:30 PM   #6
Smith & Sons
Mike,IF you were to look for the Dana 60,what would it be in & is that an 8 lug? Thanks
Old 12-25-2015, 08:36 PM   #7
Gimme Jimmy
You could find a (inexpensive) used Dana 60 with a 3.54 ratio from a big block truck that would be a bolt-in swap.
Gimme Jimmy is offline   Reply With Quote
Old 12-25-2015, 09:22 PM   #8
Mike C
Mike C's Avatar
What he said. 69-72 C20 Chevy or GMC with a coil sprung rear. Would have needed to be a big block truck most likely for the 3.54 gear set.
44 Willys MB
52 M38A1
64 Corvette Coupe
