Not the nightly winner
hei wiring
hey guys need a little help,going from points to hei on my 250 i6,need to know what to run for wiring and from where.
thought i had a diagram saved but can't find it ,i know this has been on the boards before. Thanks Todd
72C10SWB BLUE 350/350 86K10LWB BLUE 5.7 700r4 7.5' fisher plow 93S10XCAB4X4 BLUE 4.3 4L60e 69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green 86k15 swb5.0L 4spd brown |
ttt......anybody?
Truck Farmer
All you need is a hot lead from the ignition to fire the HEI. Should be able to use the + lead from your stock coil.
Arizona rust free sheetmetal |
This attached image may help. I found it here a few days back.
A "key" feature is getting the "pink" 12 gage wire directly to your new distributor. You can also completely remove the "yellow wire" going to your starter solenoid (on the starter for my '71 Cheyenne). I believe that others have had problems using the old "+" lead to your coil, because the these leads were intentionally made "resistive" to reduce voltage to the coil (to around 7 volts or so). The new HEI needs the full 12 volts. Orion 762 |
67-72 truck surgeon
Yes, Orion is right that the stock coil wire will not supply full power that the HEI needs. I ran a wire from the "ignition unfused" terminal on the fuse block to the distributer. It works fine.
1969 Chevy C10 1993 Toyota Camry LE 1999 Ford F250 Super Duty 4x4 diesel 2008 Dodge Charger Super Bee 1953 International R182 |
thanks guys,that diagram was the one i was lookin for..
![]() Join Date: Sep 2002
Certifiably crazy person |
hey lou,,,,i think we have met before you stopped at my shop and wanted to buy my truck from me,bout a year or more ago,if your the lou with the small egine repair.if not its nice to meet someone local.
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
biglou55 is it possible for you to fax a copy or mail a copy of the instuctions? Let me know I can PM you with the number or address.
-Ron- ![]() |
