Bmi built 66
Well I've been designing this back suspension for a month or so and im finally getting started on the build. Ill Post pictures as I go.
The truck is a 66 big window short box. At this time I'm only doing the back suspension but I think I will end up doing most of the truck. Custom bent Art Morrison rails, my design for a 4 link setup and more. Let me know what you think so far. |
Re: Bmi built 66
more pics
Re: Bmi built 66
where Im at so far
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Bmi built 66
Lookin good Casey
![]() I see you got those rails notched.
Re: Bmi built 66
very nice!!
http://67-72chevytrucks.com/vboard/s...d.php?t=649661 |
Re: Bmi built 66
Re: Bmi built 66
Re: Bmi built 66
started welding the the back half together
Re: Bmi built 66
All the welds have been ground smooth to make it look as if it was one piece.
Tonight I drew up a drive shaft loop that Should be cut out in the next day or so, and at that point I will be able to get the 4 link mounts welded in the front. |
Re: Bmi built 66
Drive line loop has been cut out. Now just need to get some 2x4 tubing so I can weld this stuff together!
Re: Bmi built 66
Great fab work! This build is on another level.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
Re: Bmi built 66
#13 |
Re: Bmi built 66
Makes me want to start from scratch! I'll be watching this one.
#14 |
Re: Bmi built 66
#15 |
60-66 Nut
Re: Bmi built 66
OK, Now I need to know who you know with a CNC plasma or laser that works that quick and on weekends
#16 |
Re: Bmi built 66
It's a guy in rathdrum. His business name is red beard fab shop. He has a 4x4 plasma table. The cut on the 1/4 isn't as nice as the laser stuff but it's plenty good for me. Cost for the drive line loop was $60 and $40 in bolts washers and nuts.
#17 |
Re: Bmi built 66
I spent a few hours in the garage today. I got the drive line loop installed which is also the front crosbar for the 4 link mounts. Then I welded the front 4 link mounts on. now I just need to make a few peices to help the front flow a little and it will be time to start cutting the old swb frame up.
#18 |
Re: Bmi built 66
more pics
#19 |
Re: Bmi built 66
Nice work fitting the Morrison part's. This is a cool build.
The Snortin' Bull |
#20 |
Re: Bmi built 66
#21 |
Re: Bmi built 66
Well the garage is a mess,
The back half is pretty much ready to be welded to the old frame. This thread isnt getting much feed back so ill take it as a good thing : ) Also the rear end is not centered in these pics. I just really wanted to set it in there |
#22 |
Re: Bmi built 66
more pics
#23 |
Re: Bmi built 66
last pic for the night
#24 |
Re: Bmi built 66
Don't worry about slow thread response they are all just speechless , In aw of your skill's. It seem's most seem to chime in if it's shiny and painted but not during building not sure why?
The Snortin' Bull |
#25 |
Re: Bmi built 66
Very nice work
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
