Old 12-25-2015, 09:36 AM   #1
Jemezcrusher
CPP VS GM Car Front Brakes
I plan on a dropped axle and will change to front discs when that is all apart. I see that CPP has a kit that includes everything and utilizes the stock spindle with several choices on bolt pattern.
I also understand 54 Chevy car spindles can be used too. Is their a reason to go with the car spindles and covert those to disc's, or is the CPP system a good choice?
Jemezcrusher is offline   Reply With Quote
Old 12-26-2015, 10:02 AM   #2
Coach529
Coach529's Avatar
Re: CPP VS GM Car Front Brakes
I used the kit from Speedway on my solid axle. Super easy to install and worked great.
http://www.speedwaymotors.com/Deluxe...ckup,4622.html
You could also just buy the brake caliper mounts and source the remainder of the parts at a junk yard or local Auto Parts Store.
http://www.speedwaymotors.com/Basic-...ckup,7688.html
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 12-26-2015, 10:19 AM   #3
Jemezcrusher
THanks Coach!
That looks like a pretty good price too. What master cylinder did you go to?
Old 12-26-2015, 10:23 AM   #4
tmoble
I'd be looking hard at that Speedway kit deal. Hard to beat because it's complete including hoses. CPP? not so much.
tmoble is offline   Reply With Quote
Old 12-26-2015, 10:47 AM   #5
Coach529
Coach529's Avatar
Originally Posted by Jemezcrusher View Post
THanks Coach!
I do not recall exactly where I sourced it from. It is a dual MC with a Prop Valve. Similar to the LMC 37-8553.
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=88
1949 Chevy 3600
Old 12-26-2015, 08:57 PM   #6
72Mountaineer
72Mountaineer's Avatar
See what "kind" of brakes they are. My CPP kit of a couple years ago used S10 brakes.
72Mountaineer is offline   Reply With Quote
