Need some help here please. I am trying to remove the adhesive residue on my cab left behind after removing a headliner and foam pad and some funky carpet like stuff on the kick panels. I have tried sanding, grinding, paint thinner, mineral spirits, fingernail polish remover,and WD-40. Nothing seems to be taking this stuff off. Anyone got any ideas??? Any help is appreciated. Thanks!
72 Chevy SWB 4x4 8 inch lift, white face gauges, side marker light gas filler, tilt, tach, buckets, AR39's runnin on 36.5's |
Gasoline. Let it soak in, then scrape it off with a peice of plastic. Then use something to get rid of the gasoline. Just dont huff it or light it on fire
![]() Good Luck. CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
Flamin' Bass
Hi Blazer Gal, welcome to the Board....
3M makes a $$ product, General Purpose Adhesive Remover, #08984. I too, was trying to remove old contact cement and had no luck, but this stuff started working right away. Took a couple of applications to get all the old cement off, but it did eventually work, (and didn't harm my new paint, either). Good Luck,
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
or try a hairdryer and a scrapper
![]() Join Date: Jan 2001
Don't use the heat gun after the gasoline though. I too have had good luck with the 3M stuff.
Bernie |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Try ooop's it seem's to work well for me..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
hi , I agree the 3M General Purpose Adhesive Remover is good stuff . Just soak it down , let it set for a few , then use filler spreader and scrape off heavy. Works real well ....
