Old 12-26-2015, 03:21 PM   #1
jakesblazer
2WD Blazer winter project!
Hey guys. My blazer is a 1972 2wd with the 250 l6 3speed manual. I got this truck for a project many years ago and never finished it due to a move and bla bla. When i got it the engine was rebuilt with new flat pistons bored .30 and bigger cam, headers. Was done by the PO so I don't have specifics. Was told it had a high speed rear end. It had a 4 barrel aluminum intake with a 2 barrel holly carb. This setup wasn't good. I'd why but it was pumping fuel into the crankcase. Probably a carb prob? I got a stock intake manifold and a monojet carb to try and bring it back to life. Took a pause in the project for a few months, when I came back I realized the spark I used to have is gone. I used a tester and had 12v at the coil on both sides.i used a Plug light and it said no light between coil and distributor. So I'm guessing coil is bad? Now I'm currently wating on a new hei distributor with coil inside type(should be here Thursday). I decided to start this thread to keep all my pics and questions and answers all in one place. I already got a lot of info about changing over to a hei distributor from this site. I'm sure I'll have more questions before I'm done. I will post a bunch of pics soon so we can see the whole deal!
jakesblazer is offline   Reply With Quote
Old 12-26-2015, 03:51 PM   #2
jakesblazer
Re: 2WD Blazer winter project!
Pics sort of in order.
Old 12-26-2015, 03:54 PM   #3
jakesblazer
More
Old 12-31-2015, 12:28 PM   #4
jakesblazer
The distributor came in a day early so I put it in last night. upon opening the new one it looked very large and I did not think it would fit. the old distributor was very close to the block and it is much smaller. Thankfully the new distributor has a longer arm raising it out of the way enabling it to clear.
I got my spark back! Also spsprayed a little starting fluid into the intake and she pops!
Next battle figuring out what to do for a carb.any advice?
Old 01-01-2016, 02:49 PM   #5
doo142
doo142's Avatar
Looking good, you'll be cruising come spring!!
doo142 is offline   Reply With Quote
Old 01-04-2016, 04:24 PM   #6
jakesblazer
Thanks, I hope so!
Well I have here a reman Rochester monojet carburetor on a original intake manifold. I still have to time it and check the valves because it is backfiring through the carb and this shuts it down.. am I looking in the right place?
Old 01-05-2016, 08:23 PM   #7
RustyBucket
RustyBucket's Avatar
If you've got the rotor pointing at the post in the distributor cap for #1 cyl. on the compression stroke and the wires are on in the right order it'll probably run. Might have to move the distributor a little as it's turning on the starter. Have you got delivery on the accelerator pump in your new carburetor?
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 01-05-2016, 08:40 PM   #8
jakesblazer
Update time. I got the thing to fire up long enough to put a Timing light on it. The harmonic balancer mark was lighting up to the right side of the scale. I'm assuming 10° after tdc? I turned the distributor and it went to 0°. Idle smooth out and increased signifigantly. I used the key to turn it off.. good feeling..haha The balancer is spinning clockwise from left to right on the scale. So it should hit to the left of 0°correct? Thanks
Old 01-05-2016, 08:56 PM   #9
jakesblazer
I want to play with the timing and tune the carb more but I have a new pressing issue. Something dropped between my grille and radiator and broke a fin..
it's brass so I am going to try to solder it..
