Old 09-18-2003, 08:19 PM   #1
DIGoogs
jumps and hops going into reverse
My 67, 6 cyl, manual, C30 hops and jumps when releasing the clutch in reverse. as in - it is never smooth starting in reverse.
It has been doing that as long as I can remember, even after a full clutch job and some work in the tranny.
Are we loooking at the nature of beast?
DIGoogs is offline   Reply With Quote
Old 09-18-2003, 08:35 PM   #2
jef5150
Inline 69
jef5150's Avatar
mine does the same thing,,,,69,6cyl,4-speed.....jeff
jef5150 is offline   Reply With Quote
Old 09-18-2003, 09:56 PM   #3
1972ChevyGuy
1972ChevyGuy's Avatar
I remember a post about this not too long ago, too bad i can't remember what it said Wheel hop maybe? I beleive I remember something about the rear-end moves a touch when you go backward and it does something... (bad memory)
1972ChevyGuy is offline   Reply With Quote
Old 09-18-2003, 10:18 PM   #4
Jefe
Jefe's Avatar
Clutch is warped slightly.
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed
-1968 Chevy SWB = numbers matching 307/Truck 4 speed.
-1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC
-1972 Chevy Nova = 2 door/412 Small Block
-1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything.
Jefe is offline   Reply With Quote
Old 09-18-2003, 10:48 PM   #5
Shane
Shane's Avatar
you guys have coil springs? right?
Shane is offline   Reply With Quote
Old 09-18-2003, 11:04 PM   #6
1972ChevyGuy
Mine does it and yes, coils. Thats what it was, but I still dont remember the solution
Old 09-18-2003, 11:14 PM   #7
gr8scott51
gr8scott51's Avatar
clutch
A new clutch will do wonders. Even with coil springs.
good luck, scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 09-19-2003, 07:35 AM   #8
DIGoogs
Thanks for all the "get backs"
I did put a new clutch and all the other stuff not long ago (at least as far as mileage) If the clutch did take a slight warp, I would think I would feel something in forward gears? Which I don't ....... make sense?
It’s not a showstopper but ever try to parallel park a 9 foot bed with the thing hopping and jumping and no power steering
(I know, stop whining!!)
I feel like I’m about to take out one guy’s left rear corner panel, the other guy’s front bumper and any nearby parking meters while my head is bouncing back and forth off the windshield
(not that bad!! but ....)
hahaha
Old 09-19-2003, 08:47 AM   #9
tom hand
CCRider
tom hand's Avatar
I would say you have two problems at work here. First your clutch is not as smooth as it should be...did you have the flywheel surfaced when you replaced the clutch? Did you replace the pilot bearing?...makes a huge difference. Second you have some slack in your driveline. Motor mounts,transmission mounts,u-joints, even slack in the ring and pinion...when you put in reverce all this slack is taken up because every thing gets moved in the opposite direction. Fix the clutch first.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-20-2003, 01:37 PM   #10
jimfulco
My '69 used to do that so bad the hood would vibrate in synch with it so loud it would wake the dead. I replaced the rear motor mounts & it's much better now.
jimfulco is offline   Reply With Quote
Old 09-21-2003, 01:54 PM   #11
DIGoogs
Thanks guys - all good advice:
I have to add, the thing does sit for long periods (I know I should get it out more) so I think the flywheel & pressure plate may build up surface rust. I should drive it hard for a week or so.
When I get back under there, I'll give all the good things above a look.
The one thing I love about this truck, it is so easy to work on.
Old 09-21-2003, 02:20 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Give the motor mounts a real good looking at.
With the hood open and the parking brake on (and no one in the way) Put the truck in reverse and look at the engine as you ease the clutch out. If the engine looks like it is about to pop out and land in the driveway, then you are in need of new mounts.
The fact that your truck doesn't do the jumping act in first gear tells me that the clutch adnd flywheel are fine.
