Old 12-26-2015, 09:28 PM   #1
thumper56
Erratic Speedometer
My 56 truck has a TH350 tranny and stock instrument cluster.
This combo has not had speedo as of yet. Just put in a new cable and did calculations for correct driven gear size in respect to differential, tire size/ rotation per mile, and drive gear. Gear I came up with is not a perfect match for the equations sum- but close.
Problem is now speedometer has come to life- but reads EXTREMELY erratically. As I just start to roll- it jumps to 40 mph then back to 10, up to 50 etc. No noises are heard, and all connections are secure.
Question is... is this indicative of a faulty speedometer gauge? I have never been inside one of these critters so understand they are a precision device but don't know how they tick.
thumper56 is offline   Reply With Quote
Old 12-27-2015, 12:19 AM   #2
mr48chev
mr48chev's Avatar
Re: Erratic Speedometer
You did lube the cable when you put it in?
Is the housing routed smoothly without any real tight bends?
I've taken a lot of speedometers apart and cleaned them and reset the odometer but I'd be hard pressed to write a tutorial on how to do it.
My ongoing truck projects:
Old 12-27-2015, 09:00 AM   #3
thumper56
Good points. There are no sharp bends but I did not lube the cable as it slid and rotated super easy in the sheath- will lube it.
But what triggered you to clean your speedo? Was it noisy or operated erratically? Other than just plain not functioning, what are the indicators that service/ replacement should be done to the gauge itself?
