9.5" wheel with 285mm tire on the front?
looking at running an 18x9.5 with a 285/40. this tire is 27" tall and 11.42" sidewall to sidewall. the truck will have CPP modular drop spindles and 79 C10 control arms with 2" drop springs. currently have 275/60/15 on 8" rallies all around with no rubbing anywhere. possible to fit this 18" wheel/tire combo under the front without rubbing?
![]() ![]() Join Date: Jul 2002
Re: 9.5" wheel with 285mm tire on the front?
That is a LOT of wheel and tire for the front. Can't say I have seen anyone go that big on one they will actually drive. I'd say and 8 or 8.5 wide rim with about a 245/ 40/45 would be about the size.
Here is some pictures. I run the 245/45/18 Nitto 555s. Front and 295/45 rear. If your lower the inner fenders will rub with a wide tire.
http://67-72chevytrucks.com/vboard/s...d.php?t=602275
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
The truck is currently lowered with cut spring (that way when I bought it) and has a 275 on the front without any rubbing. I may order the rear wheels and tires and see how they fit on the front. If I don't like them, I'll order a set of 8" wide with some 255s.
