Old 12-27-2015, 10:01 AM   #1
superfly66
Horn Demons..Help!
I was trying to install a new seat in my 66 and I dont know if by moving the seat in and out that it may have hit something while doing so (its stock and not adjustable so that big steering wheel is in the way)and the horn just starts going off. So, i took the cover off the steering wheel and took out the tiny switch in it and it still just goes off when i plug the horn back up. Now my truck battery is dead. I havent driven it in a few weeks because of this horror of a seat install. But anyone know what this might be causing the horn to stay on? I have installed a new turn signal switch months ago and had no problem. Even though the horn was always sensitive to the slightest push. And even though the horn is disconnected to the horn could some how have something to do with my battery dying?
superfly66 is offline   Reply With Quote
Old 12-27-2015, 12:22 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Horn Demons..Help!
The horn goes through a relay IIRC. Even with the horn disconnected, the relay would still be powered and drain the battery. You might have a short in the column wiring or the contacts are not releasing under the horn button.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-27-2015, 10:52 PM   #3
superfly66
I took the horn button out and it was still going off. I disconnected the horn from that relay under the hood. And the relay was hot as I was trying to charge the battery. What else is that relay used for? And thanks for the response.
Old 12-27-2015, 11:01 PM   #4
chevy_mike
chevy_mike's Avatar
I think only the horn.
Old 12-28-2015, 10:35 PM   #5
luvbowties
luvbowties's Avatar
Smile Re: Horn Demons..Help!
The relay contacts themselves may be stuck?
Sam
luvbowties is offline   Reply With Quote
Old 12-28-2015, 10:55 PM   #6
superfly66
there are other wires going to that relay. I havent traced any of them to find out what they are yet. Thanks again.
Old 12-28-2015, 10:57 PM   #7
superfly66
Sam
So, are you saying the relay may need to be replaced? I have yet to trace the wire in the column or to under the hood. As its dark when I get home and the rain wont stop! I only have a carport to work in. Thanks
Old 12-28-2015, 11:48 PM   #8
jtrichard
The relay is used for a junction for the main power wire on some years
jtrichard is offline   Reply With Quote
