Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-27-2015, 05:22 PM   #1
monte0185
monte0185's Avatar
Battery Disconnect
Would it pass tech inspection if I mounted my battery disconnect on the side of my truck like this? It has the on off decal I just mocked this up for reference of where I'm talking about. What do yall think?
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 12-27-2015, 06:13 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Battery Disconnect
Pretty sure the rule state has to be on the rear of the vehicle, don't have my book handy at the moment..
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-27-2015, 06:15 PM   #3
monte0185
monte0185's Avatar
8:4 MASTER CUTOFF
Mandatory when battery is relocated, or as outlined in Class
Requirements. An electrical power cutoff switch (one only) must be
installed on the rearmost part of each vehicle and be easily
accessible from outside the car body. This cutoff switch must be
connected to the positive side of the electrical system and must
stop all electrical functions including magneto ignition. The off
position must be clearly indicated with the word “OFF.” If switch is
“push/pull” type, “push” must be the action for shutting off the
electrical system, “pull” to turn it on. Any rods or cables used to
activate the switch must be minimum 1/8-inch diameter. Plastic or
keyed switches prohibited. Switches and/or controls must be
located behind rear wheels on rear-engine dragsters.
Technically its part of the rear most part. lol
Old 12-27-2015, 07:32 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
I'm sure tech will argue that one, Rear-most means BACK,, unless it's a dragster which really has no 'width ' at the back.
Also, that looks like a decent one, but I can't ID it. Many of the cheep rotary disconnects are only rated for 20-40 continuous amps. (a complete JOKE!)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-27-2015, 07:42 PM   #5
monte0185
monte0185's Avatar
Its summits brand. looks just like flaming river with a summit sticker. 250 continuous 2500 surge amps. Im gonna eventually run dual batteries so didnt want to waste money on the cheaper one. the problem Im running into is the back of the truck the handle runs into everything wherever i put it. I really should have bought the push pull type. I can get a kit to make it a push pull type but its like another 60$ i didnt really wanna spend till i get my dually lowered and on air.
Old 12-28-2015, 08:23 AM   #6
Marv D
Marv D's Avatar
If your doing dual batteries,,,, might consider isolating each and not running both through one switch. Bickel is quite proud of everything they sell,, but honestly quality is next to none.
This kit has dual 125 continuous switches, but for another $40 or so you can get dual 300 amp switches.
http://www.jerrybickel.com/batteries...-jbrc1026.html
Old 12-28-2015, 06:24 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
Thiat will not pass tech. The switch activation has to be accessible at the rear plane of the vehicle in case the vehicle ends up stopped with one side or the other up against a wall or barrier. The switch itself can be inboard, but the activation has to be to the rear. This is how I had my switch mounted on my old Super Gas car (just ahead of the driver side battery on the chassis)...
...note the activation lever protrudes to the outside of the trunk. You will also need to have a notation (sticker, lettering, etc.) that indicates which direction the switch shuts off the electrical system. If it is a push/pull activation, push has to be the OFF.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-28-2015, 07:05 PM   #8
68racer
Yeah baby!
68racer's Avatar
I mounted mine in the license plate area of the rear bumper.
11.37 @116
68racer is offline   Reply With Quote
Old 12-29-2015, 10:24 PM   #9
monte0185
monte0185's Avatar
I talked to one of the tech guys at the track and he said it has to be on the back as well. Im going to run mine like yours but will have to do it at a later date. Im just going to mount it to the frame where I can run a rod at a later date before i take it to the track. I have to finish wiring this truck so i can get my dually on bags before LST.
Old 01-02-2016, 05:31 PM   #10
HAULIN' IT
I ran mine through the bumper. Lorne
HAULIN' IT is offline   Reply With Quote
Old 01-07-2016, 12:03 AM   #11
monte0185
monte0185's Avatar
I dont have a bumper to run mine through but I have a plan. Stay Tuned...
Old 01-07-2016, 10:02 AM   #12
djracer
djracer's Avatar
Mine run through my rear roll pan with a remote switch.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-07-2016, 10:47 AM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Take the 2 bolts for the tail light mount and build a bracket that bolts on right there . wires will still be close to the same spot , body wont be modified , and it is visible and accessible from the rear .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-07-2016, 11:07 PM   #14
monte0185
monte0185's Avatar
Well this was my solution. Still need to mount it better but license plate will go in the middle. Ill have to add bolts on the outer edges for stability.
Old 01-08-2016, 09:35 PM   #15
monte0185
monte0185's Avatar
Well here's the finished product. Kinda hoaky but it works. Now to just to wire it all up..
Old 01-09-2016, 11:11 PM   #16
vin63
vin63's Avatar
Nice! Be sure there is support at the rear of the panel to keep it from flexing out since there is a significant high pressure area at the point just behind the panel when the truck is at speed.
Old 01-09-2016, 11:21 PM   #17
monte0185
monte0185's Avatar
The place it's bolted to is actually the last bed brace which is a c channel type brace so it won't flex. I bolted it through both sides as well. The aluminum is also thick so it wont flex either.
Old 01-19-2016, 03:30 PM   #18
ptc
ptc's Avatar
This is a very simple and economical way to do it. It will mount just about anyplace with just a 1/2" drilled hole. Bumper, rear fender, rollpan....
125A Switch (carrys most any street vehicle) for $35
http://www.jerrybickel.com/batteries...-jbrc5513.html
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 01-19-2016, 04:00 PM   #19
monte0185
monte0185's Avatar
Its all finished up now. Rewired the whole truck front to back.. here is a shot of the finished product on the back.
Old 01-19-2016, 04:04 PM   #20
ptc
ptc's Avatar
That looks awesome! -- nice rig!
