I have a 1960 gauge wiring question
I have a gauge cluster with dummy lights and I bought a replacement cluster with an actual amp gauge and tach. Can I just cut the bulb wires from the dummy gauge and splice them to the amp gauge?
I did just that and when I turned the key on the amp needle shot to C and when I turned the key off the truck still kept running. I switched the pink wire to the brown wire terminal on the gauge and got the same result. |
![]() Join Date: Jan 2011
Re: I have a 1960 gauge wiring question
No you can not wire an amp gauge like a volt gauge. Will take a good bit of rewire to make the amp gauge work. I would not run it if it were my truck. A volt gauge will do a much better job.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
