12-28-2015, 12:55 PM | #1 |
Glue for Vinyl Door Panel Skins
Want to reglue original vinyl door skins on to new metal door panels. Any recommendations for what glue to use? Don't want to redo this job in a year because the glue didn't hold. THX.
12-28-2015, 01:01 PM | #2 |
Re: Glue for Vinyl Door Panel Skins
X2
12-28-2015, 01:58 PM | #3 |
Probably a good bet would be to use 3M spray adhesive. It comes in normal and heavy duty. I used it to patch up my carpet on my 74 Bronco and it worked well.
12-28-2015, 02:00 PM | #4 |
Dave,
Will certainly keep that in mind, but those door panels will be fighting gravity vice embracing it like a carpet. Thanks. |
12-28-2015, 02:03 PM | #5 |
The stuff is called yellow super trim adhesive and this is what it's for--the carpet deal was a side application which was a tough one and worked well.
12-28-2015, 02:57 PM | #6 |
3M. If you want to get Hardcode, go Super 90. Otherwise 77.
I used 90 on my headliner. It's permanent.
12-28-2015, 03:12 PM | #7 |
Moderator
Use the 3m adhesive, it's about $25 a can but works fantastic. I used it on my headliner, no sags or wrinkles.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-28-2015, 05:00 PM | #8 |
I buy my 3M Super 90 at our local Lowe's for less than $15/can.
12-28-2015, 05:29 PM | #9 |
Weld wood is great if you can find it.
12-28-2015, 06:50 PM | #10 |
Most upholstery shops and street rod builders use landau top and trim adhesive for automobile applications. This includes headliners, vinyl tops and other trim apps. Stands up to the extreme heat the sun imposes on cars and trucks.
Mike |
12-28-2015, 08:16 PM | #11 |
3M trim adhesive not the general but the other. It will hold it. Jim
12-29-2015, 09:29 AM | #12 |
Headed to Lowe's today. Many thx to all. I love this board.......
