Old 12-28-2015, 10:01 PM   #1
Cautrell05
Gauge faces
Is there a place to get custom gauge faces made for the AD trucks? Going to experiment with a gutted S10 clusterand the stock housings.
Fast, Cheap, Reliable. You may pick two
My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723
Cautrell05 is offline   Reply With Quote
Old 12-28-2015, 11:59 PM   #2
joedoh
joedoh's Avatar
Re: Gauge faces
lay them on a scanner and edit them yourself in MS paint. Then print them and laminate them. They arent backlit, they are edgelit, so there is no problem with having them be solid instead of transparent.
You will realize with a custom set that the temp and the oil pressure will read backwards if you use the s10 steppers. I did this on my 47 and it worked great except for the two backwards gauges.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-29-2015, 09:26 PM   #3
Cautrell05
Re: Gauge faces
The project boogie build is where I got the idea to use the S10 gauges. I have two clusters to play with. The stock 91 unit was temp, fuel and Speedo and I have a 95 unit with full gauges. These are the earlier versions with no circuit board. The stepper motors are simple power, ground and signal. Should be real easy to wire up. I'm still think there is something with that fourth terminal on the back. Also thought about wiring it backwards to see if the gauge sweeps the opposite direction.
Old 12-30-2015, 10:22 AM   #4
Clay54
Re: Gauge faces
Your comment about wiring the stepper backwards; I have read on several threads on this site where they were going to try to reverse poles but no one has ever said if it worked or not. Would be excited to know if it really works. Clay
Clay54 is offline   Reply With Quote
Old 12-30-2015, 01:04 PM   #5
joedoh
joedoh's Avatar
Re: Gauge faces
I tried reversing the coil on the steppers on my 47 and it did not reverse the direction. in any event, if you are making new faces, just reverse the direction of the gauge text. I left the old faces and penned in the correct readings with a gold sharpie.
Old 12-30-2015, 03:51 PM   #6
Clay54
Re: Gauge faces
OK, thanks Joedoh. Looks like that is the way it has to be. Clay
Old 12-30-2015, 11:35 PM   #7
Cautrell05
Re: Gauge faces
When I get around to it I will make sure to post my findings. Good bad or otherwise.
Nick
