12-28-2015, 10:20 PM | #1 |
anyone runnning 2015 Jeep Cherokee Wheels?
Anyone running 2015 Jeep Cherokee 17" wheels on lowered 63 C10
I'm installing 2.5 drop spindles and 2. drop spring in front, and will level the rear of truck to match. Just wondering if this set up would work, before I purchase these wheels. Thanks in advance! |
12-28-2015, 10:44 PM | #2 | |
Re: anyone runnning 2015 Jeep Cherokee Wheels?
Sam Last edited by luvbowties; 12-28-2015 at 10:45 PM. Reason: spell |
12-28-2015, 11:03 PM | #3 |
Yes, the ones I'm thinking of would be 5 lug wheels
12-29-2015, 02:01 AM | #4 |
60-66 Nut
I know nothing about those wheels but you will want to verify that the bolt pattern is indeed 5 x 5" (most newer wheels are Metric sized), that the back spacing will work and what the hub bore diameter is.
12-29-2015, 07:02 AM | #5 |
Found this info on web:
http://www.oewheelsllc.com/Wheels_3/...HlQaAvff8P8HAQ SKU#: JP20-17075-5127-44S-OEM-WT WHEEL SIZE: 17x7.5 WHEEL OFFSET: 44 BOLT PATTERN: 5-127 HUB SIZE: 71.5 BACK SPACING: 5.98228347 CENTER CAPS: Factory center cap included. TIRE PRODUCT: Goodyear Wrangler SR-A TIRE SIZE: 255-75-17 SPEED RATING: S TEMP RATING: B TRACTION RATING: A TREADWEAR RATING: 127/25.4=5. (So bolt pattern looks good, but I get lost very quickly when talking offset or ha spacing, and what offset will work for our trucks) Last edited by 63frankintruck; 12-29-2015 at 07:08 AM. |
12-29-2015, 01:44 PM | #6 |
Domer has them on a square: http://67-72chevytrucks.com/vboard/s...0&postcount=28
He can tell you what work went into making them fit. I know its a different year but he might be helpful.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
