Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-29-2015, 12:35 PM   #1
Tynee
I miss this truck.
Tynee's Avatar
Low-Buck Base setup
Good morning truck audiophiles. I just replaced the head unit in my '08 Crew Cab with a Kenwood DDX372BT:
Kenwood Head Unit
I replaced the front door speakers and tweeters with Alpine SPS-610C's:
Front Doors and Tweeters
And the rear door speakers with Polk DB651S's:
Rear Doors
I'm powering the speakers directly from the head unit. I'd like to fill out the low end that I'm currently missing, but don't want to spend a ton. When I took this question to the local car audio shop, their recommendation was a $650 setup. I'm looking to get by for less than $200.
I'm thinking about this setup under the rear seat:
P300-10 P300-10
Can anybody point me in the right direction for a separate 10" Sub, amp, and enclosure that would beat the sound quality of this Rockford Fosgate setup without being TOO much more expensive?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-30-2015, 03:14 PM   #2
ratedrookie
Re: Low-Buck Base setup
$200 is not a lot, but you still have options for a nice setup using some quality components. For example, you can get a sub like this:
10"
http://store.soundsolutionsaudio.com...subwoofer.html
12"
and power it with something like this:
http://www.sonicelectronix.com/item_...e-R500X1D.html
or (if you don't mind manufacturer refurbished)
http://www.bostonacoustics.com/US/Pr...onAcoustics%29
Wire either amp to a 2 Ohm load for around 400-500W of power.
I would recommend you build your own box because you can have something built to the specs of the subwoofer and it will probably cost you $30 of materials. An 8 gauge wiring kit (50 A fuse) will set you back about another $20. That will put you right around $250 for everything.
ratedrookie is offline   Reply With Quote
Old 12-30-2015, 03:53 PM   #3
Tynee
I miss this truck.
Tynee's Avatar
That's the kind of feedback I was looking for. Thanks. Do you have personal experience with any of those products?
Old 01-13-2016, 11:55 AM   #4
XwalkerX
prob not exactly what youre looking for but im no audiophile...
I installed this in my truck last week and man im really shocked at how well it performs
Amazon.com: SSL LOPRO10 Amplified Subwoofer... Amazon.com: SSL LOPRO10 Amplified Subwoofer...
XwalkerX is offline   Reply With Quote
Old 01-13-2016, 06:28 PM   #5
jamesjones
Freakin Awesome!
jamesjones's Avatar
Kenwood Head Unit
Rear Doors
P300-10
This sub...
http://www.sonicelectronix.com/item_...nce-1060W.html
with this amp...
http://www.sonicelectronix.com/item_...PI-P600.2.html
will have you sounding equal or better for a fraction of the price. You should have enough left over to either buy the materials and build your own box or buy a cheap ebay prefab box and add some glue to it.
I installed two of the 12" version of those Infinities into by friends Charger and he was blown away by the price/performance ratio.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 01-15-2016, 09:17 AM   #6
Tynee
I miss this truck.
Tynee's Avatar
Thanks for the feedback, guys.
