Old 12-29-2015, 03:16 PM   #1
Bowler
carburetor problems.
Good afternoon everyone. I just bought a 64 c10 and when I got it found out it was a 350 and has a 4 barrel Quadrajet M4 I think the numbers for it are 7045214YP 0336. I am thinking the guy who owned it before made it a two barrel for some reason. The vacuum breaker is not hooked up and he made it so the two front ports are always open. Any input with this I haven't ever worked with a 4 barrel. Is it worth rebuilding and spending the money there or should i buy a new Carburetor? Thanks in advance.
Bowler is offline   Reply With Quote
Old 12-29-2015, 03:24 PM   #2
schpeen
schpeen's Avatar
Re: carburetor problems.
FiTech Fuel Injection 30001: FiTech Fuel Injection Fuel Injection Systems
schpeen is offline   Reply With Quote
Old 12-29-2015, 04:39 PM   #3
gar187er
When I got my 65, it had a remanned Qjet from 97 on it. Ran like crap, had to jack up the idle just to keep it running. I left it on there for a week to get it through inspection, then first thing I did was buy a NEW holley. Slapped it on a new manifold; and its one less thing to worry about.
I didn't have the time or patience to rebuild the Qjet; which looked close to the condition yours is in.
gar187er is offline   Reply With Quote
Old 12-29-2015, 05:58 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
A nice 600 CFM edelbrock with a manual choke goes for $289 at Auto Zone.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-29-2015, 06:06 PM   #5
OldChevy61
OldChevy61's Avatar
I have never owned a qjet worth a crap. I second the holley. You can get a spread bore holley that will bolt rite on the qjet intake.
OldChevy61 is offline   Reply With Quote
Old 12-29-2015, 09:41 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You can't "make" a 4 bbl a 2 bbl.
Those top butterflys over the back barrels on a Q-jet will not open unless the engine is under a load. So you can wap the throttle in Park in the driveway all day long and they won't open.
The "front ports" is just the choke flap open over the front 2 barrels.
So not sure what the question is... but I bet it's running exactly as it's supposed to.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-29-2015, 10:02 PM   #7
cadillac_al
The PO probably just robbed the vacuum break to put on another carb. I would buy a new vacuum break ($10?) and read a few articles on Qjets and play with it a little and see how it runs.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-29-2015, 10:08 PM   #8
trac209
From the pictures that carb isn't working like it supposed to. For one the choke flap doesn't even have the rod hooked up. The vacuum break also has to be hooked up. Since your expertise is limited I'd either have this one rebuilt or buy a new qjet.
trac209 is offline   Reply With Quote
Old 12-30-2015, 03:39 PM   #9
dracko
dracko's Avatar
Give that Qjet a little TLC and she'll purrr
dracko is offline   Reply With Quote
Old 12-30-2015, 04:00 PM   #10
schpeen
schpeen's Avatar
Old 12-30-2015, 04:14 PM   #11
trac209
Are you going to post that on every carb post lol
Old 12-30-2015, 05:02 PM   #12
slotard
probably twice on each one
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-30-2015, 06:09 PM   #13
trac209
Ha I never noticed the two times but I notice every carb question he post the same thing and nothing of the question at hand. Kind of annoying
Old 12-30-2015, 09:34 PM   #14
schpeen
schpeen's Avatar
it was a joke sorry i wasn't aware this was a serious crowd
Old 12-30-2015, 09:37 PM   #15
schpeen
schpeen's Avatar
i will give you a great deal on my 6 month old Holly 750 as soon as my EFI arrives!
